Hey guys,I got my tlt docker installed and have a critically imbalanced dataset, so I need do some dataset augmentation. I tried to use the command ‘tlt-augment’ in the docker and jupyter notebook, but both of them doesn’t work. It’s end up with’ command not found’. I knew it from ‘Integrating TAO Models into DeepStream — TAO Toolkit 3.22.05 documentation’. Is it removed or I need to do some extra installition? Or I heard that add the augment config might be work, can someone provide me more detail? Thanks a lot.
It’s end up with’ command not found ’.
Could you please share the full command and full log?
Hi, here it is
I open the jupyter notebook
notebooks/examples/augment/augment.ipynb
and can find the command.
Please check if you can.
Sorry we didn’t found it. Where is the directry “notebooks”, is it in the docker /workspace/ ?
Did you use the latest TLT docker 2.0_py3? If yes, after triggering the jupyter notebook, you will find the examples/augment/augment.ipynb
I was using tlt docker 2.0 py2. Is it too old? I’m pulling the new one
Hi, the problem solved. I downloaded the newest tlt docker, and the command is functioning. Thanks a lot!
