Hello everyone,
I have already opened a thread covering the driver initialization issue:
Related discussion: Tesla V100-PCIE-32GB detected as V100-SXM2-32GB on Windows (Code 10, driver won’t start)
This new topic is not about the driver issue itself. I would like to focus specifically on how to verify whether the installed VBIOS is correct before considering any firmware changes.
Background
The physical GPU installed in my workstation is labeled as:
- Model: Tesla V100-PCIE-32GB
- Part Number: 699-2G500-0212-400L
However, every NVIDIA Data Center driver I have tested identifies the card as:
NVIDIA Tesla V100-SXM2-32GB
Older driver 462.30 was able to initialize the GPU and nvidia-smi worked, although the card was still reported as Tesla V100-SXM2-32GB.
Newer Data Center drivers (551.78 and 582.70) fail to initialize the device and Windows reports Code 10 (CM_PROB_FAILED_START). More details are available in the linked discussion.
Hardware Information
Physical Label
Device Information
Instance ID:
PCI\VEN_10DE&DEV_1DB5&SUBSYS_124910DE&REV_A1\4&27291c47&0&0008
Device Description:
Problem Code:
Problem Status:
0xC000009A
Hardware IDs
PCI\VEN_10DE&DEV_1DB5&CC_030200
Current VBIOS Information
Obtained using NVFlash:
Build GUID : 1A634629E8A445709787DC7F202751F8
Build Number : 25341443
IFR Subsystem ID : 10DE-1249
Subsystem Vendor ID : 0x10DE
Subsystem ID : 0x1249
Version : 88.00.80.00.04
Image Hash : 81E49C0843498F789EE7C4E34D6D922B
Hierarchy ID : Normal Board
Build Date : 11/29/2018
Modification Date : 01/10/2019
UEFI Version : 0x4000A (x64)
UEFI Variant ID : 0x0000000000000008 (GV1xx)
InfoROM Version : G503.0204.00.03
My Questions
Before attempting any VBIOS update, I would like to understand whether the firmware currently installed on the card is actually correct.
- Is there a reliable way to determine whether this GPU is running the correct VBIOS for a Tesla V100-PCIE-32GB?
- Is VBIOS version 88.00.80.00.04 expected for a Tesla V100 PCIe 32GB?
- Can the NVIDIA driver legitimately identify a genuine Tesla V100 PCIe as Tesla V100-SXM2-32GB, or does that usually indicate an incorrect or OEM-specific VBIOS?
- Are the Board ID, Subsystem ID, and other firmware information sufficient to determine whether the VBIOS matches the hardware?
- If the VBIOS is incorrect, what is the recommended way to obtain the correct firmware? Should it come from NVIDIA, the original OEM, or another source?
Any suggestions or guidance would be greatly appreciated.
Thank you.
