How can one determine the temp storage size for CUB block primitives from the host?
Hi, I want to limit shared memory usage by reusing an existing shared memory allocation for CUB.
Something like:
size_t smemCub = ...
size_t smemMyAlgorithm = ...
size_t smemForKernel = max(smemCub, smemMyAlgorithm)
kernel<<<grid, block, smemForKernel>>>();
How can I compute the required amount of shared memory for CUB from the host?
The following code outputs different sizes of shared memory on the host and on the device.
#include <cub/cub.cuh>
#include <cstdio>
constexpr int blocksize = 128;
using BlockReduceInt = cub::BlockReduce<int, blocksize>;
using BlockReduceIntStorage = typename BlockReduceInt::TempStorage;
__global__
void kernel(){
    size_t size = sizeof(BlockReduceIntStorage);
    printf("device size %lu\n", size);
int main(){
    printf("host size %lu\n", size);
    kernel<<<1,1>>>();
    cudaDeviceSynchronize();
host size 980
device size 24
The problem is that CUDA_ARCH which is a defaulted template argument is not defined in host code. I found the following solution for the case when CUDA_ARCH matches the SM version of the device.
int major = 0;
    int minor = 0;
    cudaDeviceGetAttribute(&major, cudaDevAttrComputeCapabilityMajor, 0);
    cudaDeviceGetAttribute(&minor, cudaDevAttrComputeCapabilityMinor, 0);
    int arch = major * 100 + minor * 10;
    printf("arch = %d\n", arch);
    size_t size = 0;
    switch(arch){
        case 610: {
            using BlockReduceInt = cub::BlockReduce<int, blocksize, cub::BLOCK_REDUCE_WARP_REDUCTIONS, 1, 1, 610>;
            break;
        default:{
            using BlockReduceInt = cub::BlockReduce<int, blocksize, cub::BLOCK_REDUCE_WARP_REDUCTIONS, 1, 1, 200>;
            break;
