How can openmp support be used in the Nsight Eclipse environment
The following error occurred when I was using a cross-compilation environment, and I wasn’t sure which configuration bar to add “-fopenmp”.
/usr/bin/ld: ./src/main.o: undefined reference to symbol ‘omp_set_nested@@OMP_1.0
You can set some customized compiler config here:
Properties -> Build -> Settings -> Tool Settings -> NVCC Compiler -> Expert Settings.
Thank you very much for your clarification
