How can set the “tegra_car TEGRA210_CLK_CLK_OUT_3” Default Clock Rate at jetson TX1 R28.2?
I know the this below echo command to set the clk_out_3 Clock Rate.
But now I need set the “tegra_car TEGRA210_CLK_CLK_OUT_3” Default Clock Rate at jetson TX1,How can to do this?
echo 24000000 > /sys/kernel/debug/clk/clk_out_3/clk_update_rate
hello sensor_test,
yes, you’re able to use the “clk_update_rate” debugfs to overwrite the clock rate.
confirm this by checking the “clk_rate”, thanks
NVIDIA® Tegra® Board Support Package (BSP) supports configuring Tegra clocks and peripheral clocks through the software。
How can I change BSP to set TEGRA210_CLK_CLK_OUT_3 Default Clock Rates?
