Hi all,
System config
- nvidia Xavier
- jetpack 4.2
- kernel 32.1
I connected Xavier esata port <=> esata to sata cable <=> SSD 2T(samsung 860 pro).
This worked fine.
And connected Xavier esata port <=> esata to sata cable <=> SSD 4T(innodisk 3TG6-P).
The SSD 4T was recognized. but disk size was 100Mbyte.
The SSD 4T worked fine on My PC(ubuntu 18.04).
I need help.
I want to know what’s wrong.
SSD 4T(innodisk 3TG6-P) or kernel compile config.
If someone uses a SSD 4T, please let me know.
Below is the kernel log.
[ 19.344721] ata1.00: exception Emask 0x10 SAct 0x10 SErr 0x41d0002 action 0xe frozen
[ 19.344912] ata1.00: irq_stat 0x80400000, PHY RDY changed
[ 19.345020] ata1: SError: { RecovComm PHYRdyChg CommWake 10B8B Dispar DevExch }
[ 19.345152] ata1.00: failed command: READ FPDMA QUEUED
[ 19.345263] ata1.00: cmd 60/08:20:00:00:00/00:00:00:00:00/40 tag 4 ncq dma 4096 in
res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[ 19.345529] ata1.00: status: { DRDY }
[ 19.345646] ata1: hard resetting link
[ 20.656806] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 20.657253] ata1.00: model number mismatch '2.5" SATA SSD 3TG6-P' != 'ASMT109x- Config'
[ 20.657266] ata1.00: revalidation failed (errno=-19)
[ 20.657441] ata1: limiting SATA link speed to 3.0 Gbps
[ 23.194191] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.194215] Bluetooth: BNEP socket layer initialized
[ 23.745020] fuse init (API version 7.26)
[ 24.334240] snd_hda_codec_hdmi hdaudioC0D5: HDMI: audio coding type 0 not expected
[ 24.334253] snd_hda_codec_hdmi hdaudioC0D5: HDMI: audio coding type 0 not expected
[ 25.328152] tegradc 15200000.nvdisplay: unblank
[ 25.328170] tegradc 15210000.nvdisplay: blank - powerdown
[ 25.328183] tegradc 15220000.nvdisplay: blank - powerdown
[ 25.776614] ata1: hard resetting link
[ 26.252614] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 26.253167] ata1.00: model number mismatch '2.5" SATA SSD 3TG6-P' != 'ASMT109x- Config'
[ 26.253178] ata1.00: revalidation failed (errno=-19)
[ 26.253355] ata1.00: disabled
[ 31.408663] ata1: hard resetting link
[ 31.884699] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 31.885273] ata1.00: ATA-8: ASMT109x- Config, 2143 5, max UDMA/133
[ 31.885287] ata1.00: 204800 sectors, multi 1: LBA
[ 31.885893] ata1.00: configured for UDMA/133
[ 31.885968] sd 1:0:0:0: [sda] tag#4 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 31.885975] sd 1:0:0:0: [sda] tag#4 Sense Key : 0x5 [current]
[ 31.885980] sd 1:0:0:0: [sda] tag#4 ASC=0x21 ASCQ=0x4
[ 31.885987] sd 1:0:0:0: [sda] tag#4 CDB: opcode=0x88 88 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
[ 31.885996] blk_update_request: I/O error, dev sda, sector 0
[ 31.886146] Buffer I/O error on dev sda, logical block 0, async page read
[ 31.886374] ata1: EH complete
[ 31.886472] sd 1:0:0:0: rejecting I/O to offline device
[ 31.886610] sd 1:0:0:0: rejecting I/O to offline device
[ 31.886716] sda: unable to read partition table
[ 31.887156] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 31.887411] ata1.00: detaching (SCSI 1:0:0:0)
[ 31.891578] sd 1:0:0:0: [sda] Synchronizing SCSI cache
[ 31.904742] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 31.904907] ata1.00: irq_stat 0x40000001
[ 31.904989] ata1.00: failed command: FLUSH CACHE
[ 31.905090] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 5
res 51/04:00:00:00:00/00:00:00:00:00/00 Emask 0x1 (device error)
[ 31.905335] ata1.00: status: { DRDY ERR }
[ 31.905415] ata1.00: error: { ABRT }
[ 31.906846] ata1.00: configured for UDMA/133
[ 31.906859] ata1.00: device reported invalid CHS sector 0
[ 31.907023] ata1: EH complete
[ 31.916717] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 31.916884] ata1.00: irq_stat 0x40000001
[ 31.916991] ata1.00: failed command: FLUSH CACHE
[ 31.917112] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 6
[ 31.917413] ata1.00: status: { DRDY ERR }
[ 31.917524] ata1.00: error: { ABRT }
[ 31.918688] ata1.00: configured for UDMA/133
[ 31.918702] ata1.00: device reported invalid CHS sector 0
[ 31.918886] ata1: EH complete
[ 31.928764] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 31.928928] ata1.00: irq_stat 0x40000001
[ 31.929010] ata1.00: failed command: FLUSH CACHE
[ 31.929112] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 7
[ 31.943940] ata1.00: status: { DRDY ERR }
[ 31.945886] ata1.00: error: { ABRT }
[ 31.950703] ata1.00: configured for UDMA/133
[ 31.950727] ata1.00: device reported invalid CHS sector 0
[ 31.955131] ata1: EH complete
[ 31.955160] sd 1:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x00 driverbyte=0x08
[ 31.955171] sd 1:0:0:0: [sda] Sense Key : 0x5 [current]
[ 31.955178] sd 1:0:0:0: [sda] ASC=0x21 ASCQ=0x4
[ 31.955183] sd 1:0:0:0: [sda] Stopping disk
[ 31.989479] scsi 1:0:0:0: Direct-Access ATA ASMT109x- Config n/a PQ: 0 ANSI: 5
[ 32.037622] sd 1:0:0:0: [sda] 204800 512-byte logical blocks: (105 MB/100 MiB)
[ 32.038157] sd 1:0:0:0: [sda] Write Protect is off
[ 32.038316] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 32.038412] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 32.041489] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 32.336696] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 32.336873] ata1.00: irq_stat 0x40000001
[ 32.336955] ata1.00: failed command: FLUSH CACHE
[ 32.337056] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 19
[ 32.337309] ata1.00: status: { DRDY ERR }
[ 32.337387] ata1.00: error: { ABRT }
[ 32.338606] ata1.00: configured for UDMA/133
[ 32.338623] ata1.00: device reported invalid CHS sector 0
[ 32.338817] ata1: EH complete
[ 32.348664] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 32.348846] ata1.00: irq_stat 0x40000001
[ 32.348942] ata1.00: failed command: FLUSH CACHE
[ 32.349104] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 21
[ 32.349335] ata1.00: status: { DRDY ERR }
[ 32.349412] ata1.00: error: { ABRT }
[ 32.350642] ata1.00: configured for UDMA/133
[ 32.350658] ata1.00: device reported invalid CHS sector 0
[ 32.350840] ata1: EH complete
[ 32.360673] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 32.360855] ata1.00: irq_stat 0x40000001
[ 32.360930] ata1.00: failed command: FLUSH CACHE
[ 32.361027] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 23
[ 32.361265] ata1.00: status: { DRDY ERR }
[ 32.363147] ata1.00: error: { ABRT }
[ 32.368729] ata1.00: configured for UDMA/133
[ 32.368746] ata1.00: device reported invalid CHS sector 0
[ 32.372317] ata1: EH complete
[ 32.389591] ata1: limiting SATA link speed to 3.0 Gbps
[ 32.389804] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[ 32.389931] ata1.00: irq_stat 0x40000001
[ 32.390030] ata1.00: failed command: FLUSH CACHE
[ 32.392554] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 25
[ 32.406716] ata1.00: status: { DRDY ERR }
[ 32.410700] ata1.00: error: { ABRT }
[ 32.414066] ata1: hard resetting link
[ 32.888591] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320)
[ 32.889599] ata1.00: configured for UDMA/133
[ 32.889616] ata1.00: device reported invalid CHS sector 0
[ 32.889820] ata1: EH complete
[ 32.900646] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 32.900815] ata1.00: irq_stat 0x40000001
[ 32.900892] ata1.00: failed command: FLUSH CACHE
[ 32.900992] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 27
[ 32.901221] ata1.00: status: { DRDY ERR }
[ 32.901299] ata1.00: error: { ABRT }
[ 32.902462] ata1.00: configured for UDMA/133
[ 32.902482] ata1.00: device reported invalid CHS sector 0
[ 32.902671] ata1: EH complete
[ 32.912937] ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
[ 32.913096] ata1.00: irq_stat 0x40000001
[ 32.913184] ata1.00: failed command: FLUSH CACHE
[ 32.913286] ata1.00: cmd e7/00:00:00:00:00/00:00:00:00:00/a0 tag 29
[ 32.913542] ata1.00: status: { DRDY ERR }
[ 32.913627] ata1.00: error: { ABRT }
[ 32.916940] ata1.00: configured for UDMA/133
[ 32.916958] ata1.00: device reported invalid CHS sector 0
[ 32.917120] sd 1:0:0:0: [sda] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
[ 32.917126] sd 1:0:0:0: [sda] tag#29 Sense Key : 0x5 [current]
[ 32.917131] sd 1:0:0:0: [sda] tag#29 ASC=0x21 ASCQ=0x4
[ 32.917138] sd 1:0:0:0: [sda] tag#29 CDB: opcode=0x35 35 00 00 00 00 00 00 00 00 00
[ 32.917151] blk_update_request: I/O error, dev sda, sector 0
[ 32.917343] ata1: EH complete
