How can we check if an image exists inside a button in python's kivy library?
So the problem I am having is that I have placed an image inside my button object in my .kv file and I want to check that if an image exists inside the button. Now the problem here is that they both are widgets (one inside the other) so my instance method isn’t working. Below is my code.
GridLayout:
    cols: 8
    rows: 8
    padding: ("60dp", "60dp", "60dp", "60dp")
    orientation: 'tb-lr'
    Button:
        background_normal: ''
        background_color: (1,1,1,1)
        on_press: app.moves(self)
        AsyncImage:
            source: 'imgs/WhiteCastle.png'
            center_x: self.parent.center_x
            center_y: self.parent.center_y
So now I want to check if an AsyncImage exists in a button because in some other buttons that I have created it does not exist. Can someone plzzz help. Below is my .py file.
def moves(self, instance):
    all_ids = instance.parent.parent.ids.items()
    id = self.get_id(instance)
    print(id)
def get_id(self, instance):
    for id, widget in instance.parent.parent.ids.items():
        if widget.__self__ == instance:
            return id
Hi @paulspavan. Are you sure this belongs in the Omniverse forums? Omniverse Kit has it’s own UI framework for this kind of thing.
https://docs.omniverse.nvidia.com/py/kit/source/extensions/omni.ui/docs/index.html
