How can we install sample refrence graph in windows system?
**• trying deepstream graph on windows platform but i am unable to try out the sample test because their is no way to install reference graph in windows os
There are no samples for Windows as DeepStream is not supported on Windows. You can run the samples on a remote machine from Windows.
but then what is the use of Graph Composer for windows machine.
reference:
The Windows machine can be run as the remote executor. In this way, you can execute graph from Windows machine which is connected with the target machine ( dGPU or Jetson devices with Ubuntu OS) through ssh, and the graph will be downloaded and excuted in the target machine but not the executor in this mode.
Getting Started with Graph Composer (nvidia.com)
Application Workflow — DeepStream 6.1.1 Release documentation (nvidia.com)
