How can we see which cores (Cuda or TC) is used for a particular instruction on Jetson AGX Thor?
I am using Triton Language and i want to know if it is possible to see which cores (Cuda or TC) is used for a particular instruction on Jetson AGX Thor? (in any programming language).
triton_dump.py.txt (16.9 KB) and following may be useful.
git clone https://github.com/triton-lang/triton.git
cd triton
python/triton/tools/disasm.py
python/tutorials/gluon/06-tcgen05.py
docs/programming-guide/chapter-3/debugging.rst
https://github.com/triton-lang/triton?tab=readme-ov-file#tips-for-hacking
https://triton-lang.org/main/programming-guide/chapter-3/debugging.html
export TRITON_ALWAYS_COMPILE=1
export TRITON_KERNEL_DUMP=1
export TRITON_DUMP_DIR=/tmp/triton-dump
python3
python3 triton_dump.py   # Or your_program.py
grep -RniE 'tcgen05\.mma|wgmma|mma\.sync' /tmp/triton-dump
grep -RniE 'tcgen05\.mma|wgmma|mma\.sync' triton_dump
/opt/nvidia/nsight-compute/2026.3.1/ncu
/opt/nvidia/nsight-compute/2026.3.1/ncu-ui
/opt/nvidia/nsight-systems/2026.3.2/target-linux-sbsa-armv8/nsys
/opt/nvidia/nsight-systems/2026.3.2/host-linux-armv8/nsys-ui
You can use NSight Compute to profile the tasks.
It may also want to check the layout configuration of triton-lang below:
