we can see cumac can support 64TR MU-MIMO scheduler from the lastest Aerial SDK release 24-3.
However, it seems that no test case is for cumac 64TRX function. How could we test this fucntion?
I can generate 64TR testvector as below,
How can I use the TV to test 64TR MIMO between testMAC and cuMAC-CP?
eg: we can run below command to test cuMAC-CP and testMAC.
sudo $cuBB_SDK/build/cuMAC-CP/cumac_cp|
sudo $cuBB_SDK/build/cuPHY-CP/testMAC/testMAC/test_mac F08 8C_60c|
Hi @zhenming.a.cheng ,
64TR functionality was not completely integrated with cuMAC as of 24-3.
64TR support for cuMAC-CP/testMAC will be available in 25-2 release.
The testbench for stand-alone cuMAC tests of 64TR is also not complete yet. If you try stand-alone tests with 64TR configuration, you need to manually open the solution TV and check the output manually. This will be improved in 25-1 release.
Thank you.
ok, got it!
Thanks for your information!
