I encountered inference error using deepstream, so I am debugging th nvinfer plugin.
When I read the nvdsinfer source code, I found there is a void pointer sends to the enqueueV2 function(Code is attached below)
m_Context->enqueueV2(bindingBuffers.data(), stream,
(consumeEvent ? &consumeEvent->ptr() : nullptr))
I think this should be the data finally sends to the tensorrt for inference. So I want to dump this data to a txt file to see what the final data is like, but I dont know how to do this. Could anyone could give me some hints?
NvDsInferStatus
FullDimTrtBackendContext::enqueueBuffer(
const std::shared_ptr<InferBatchBuffer>& buffer, CudaStream& stream,
CudaEvent* consumeEvent)
assert(m_Context);
assert(stream.ptr());
std::vector<void*> bindingBuffers = buffer->getDeviceBuffers();
for (int iL = 0; iL < (int)m_AllLayers.size(); ++iL)
if (!m_AllLayers[iL].isInput)
continue;
NvDsInferBatchDims batchDims = buffer->getBatchDims(iL);
assert(batchDims.batchSize == buffer->getBatchDims(0).batchSize);
//fix for onnx model which has fixed input dimensions
if(batchDims.batchSize < m_AllLayers[iL].profileDims[kSELECTOR_MIN].batchSize)
batchDims.batchSize = m_AllLayers[iL].profileDims[kSELECTOR_MIN].batchSize;
if (!canSupportBatchDims(iL, batchDims))
dsInferError(
"Failed to enqueue buffer in fulldims mode because "
"binding idx: %d with batchDims: %s is not supported ",
iL, safeStr(batchDims2Str(batchDims)));
return NVDSINFER_INVALID_PARAMS;
nvinfer1::Dims dimsWBatch =
CombineDimsBatch(batchDims.dims, batchDims.batchSize);
nvinfer1::Dims lastDimsBatch = m_Context->getBindingDimensions(iL);
if (dimsWBatch != lastDimsBatch)
if (!m_Context->setBindingDimensions(iL, dimsWBatch))
dsInferError(
"Failed to enqueue buffer when setting bindings idx:%d with "
"dims:%s",
iL, safeStr(dims2Str(dimsWBatch)));
if (!m_Context->allInputDimensionsSpecified())
dsInferError(
"Failed to enqueue buffer because context dims are not specified "
"in dynamic mode");
return NVDSINFER_TENSORRT_ERROR;
if (!m_Context->enqueueV2(bindingBuffers.data(), stream,
(consumeEvent ? &consumeEvent->ptr() : nullptr)))
dsInferError("Failed to enqueue trt inference batch");
return NVDSINFER_SUCCESS;
Here is my full system configuration:
Hardware Platform (Jetson / GPU) : Xavier NX
DeepStream Version : 5.0
JetPack Version (valid for Jetson only) : 4.4
TensorRT Version : 7.1.3
