I am trying to write a per-pixel spinlock for ray tracing application.
I use a very simple test case that 2 threads share the same output pixel as shown below.
If I write the same codes in a compute shader, it works well.
However if I write it in a raygen shader, it seems to be deadlocked or somehow stall forever.
I have no idea why. My device is laptop 3070, API is vulkan, shader language is GLSL.
Thank you!
void main() {
// The resolution of the image, which is the same as the launch size:
const ivec2 resolution = ivec2(pushConstants.resolution);
const ivec2 pixel = ivec2(gl_LaunchIDEXT.xy);
// If the pixel is outside of the image, don't do anything:
if((pixel.x >= resolution.x) || (pixel.y >= resolution.y)) {
return;
ivec2 newpixel = pixel;
newpixel.x /= 2;
bool keepWaiting = true;
while(keepWaiting) {
if(imageAtomicCompSwap(atomicMutex, newpixel, 0, 1) == 0) {
// insert(...);
// memoryBarrier();
imageAtomicExchange(atomicMutex, newpixel, 0);
keepWaiting = false;
