// SPDX-License-Identifier: GPL-2.0-only
* T194 p2822-0000 audio common DTSI file.
* Copyright (c) 2017-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
#include <audio/tegra-platforms-audio-dai-links.dtsi>
#include <audio/tegra186-audio-dai-links.dtsi>
#include <audio/tegra186-audio-graph.dtsi>
#include <dt-bindings/gpio/tegra194-gpio.h>
#include <dt-bindings/audio/tegra194-audio.h>
#include <audio/tegra-platforms-audio-dmic3-5-switch.dtsi>
aconnect@2a41000 {
status = "okay";
agic-controller@2a41000 {
status = "okay";
adsp@2993000 {
status = "okay";
// //add
// clocks {
// wm8904_mclk: wm8904_mclk {
// compatible = "fixed-clock";
// #clock-cells = <0>;
// // clock-frequency = <49152000>;
// clock-frequency = <12288000>;
// clock-output-names = "wm8904-mclk";
// status = "okay";
i2c@c250000 {
add
wm8904_codec: wm8904@1a {
compatible = "wlf,wm8904";
status ="okay";
reg = <0x1a>;
// clocks = <&wm8904_mclk>;
// clocks = <&bpmp TEGRA194_CLK_AUD_MCLK>;
clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
// clocks = <&pck0>;
clock-names = "mclk";
port {
wm8904_ep: endpoint {
remote-endpoint = <&i2s1_dap_ep>;
mclk-fs = <256>;
link-name = "wm8904-playback";
// wm8904_codec: wm8904.7-001a@1a {
// compatible = "wlf,wm8904";
// reg = <0x1a>;
// /* refer include/sound/rt5659.h for the values to be used */
// realtek,jd-src = <2>; /* RT5659_JD_HDA_HEADER */
// realtek,dmic1-data-pin = <0>; /* RT5659_DMIC1_NULL */
// realtek,dmic2-data-pin = <0>; /* RT5659_DMIC2_NULL */
// /* Codec IRQ output */
// interrupt-parent = <&tegra_main_gpio>;
// interrupts = <TEGRA194_MAIN_GPIO(S, 5) GPIO_ACTIVE_HIGH>;
// clock-names = "mclk";
// #sound-dai-cells = <1>;
// sound-name-prefix = "WM";
// status = "okay";
// port {
// rt5658_ep: endpoint {
// remote-endpoint = <&i2s1_dap_ep>;
// mclk-fs = <256>;
// link-name = "wm8904-playback";
/* Default for all I2S is long fsync width(31) */
aconnect@2a41000 {
compatible = "nvidia,tegra210-aconnect";
status = "okay";
ahub {
/* I2S4 in Short frame sync for BT SCO */
i2s@2901300 {
bclk-ratio = <4>;
status = "okay";
// tegra_axbar: ahub {
// compatible = "nvidia,tegra186-ahub";
// status = "okay";
// tegra_i2s1: i2s@2901000 {
// compatible = "nvidia,tegra210-i2s";
// reg = <0x0 0x2901000 0x0 0x100>;
// clocks = <&bpmp_clks TEGRA194_CLK_I2S1>,
// <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>,
// <&bpmp_clks TEGRA194_CLK_I2S1_SYNC_INPUT>,
// <&bpmp_clks TEGRA194_CLK_SYNC_I2S1>,
// <&bpmp_clks TEGRA194_CLK_I2S1_SYNC_INPUT>;
// clock-names = "i2s","pll_a_out0", "ext_audio_sync","audio_sync", "clk_sync_input";
// assigned-clocks = <&bpmp_clks TEGRA194_CLK_I2S1>;
// assigned-clock-parents =
// <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>;
// assigned-clock-rates = <1536000>;
// fsync-width = <31>;
// sound-name-prefix = "I2S1";
// status = "okay";
// tegra_dmic1: dmic@2904000 {
// compatible = "nvidia,tegra210-dmic";
// reg = <0x0 0x2904000 0x0 0x100>;
// clocks = <&bpmp_clks TEGRA194_CLK_DMIC1>,
// clock-names = "dmic", "pll_a_out0";
// assigned-clocks = <&tegra_car TEGRA194_CLK_DMIC1>;
// <&tegra_car TEGRA194_CLK_PLLA_OUT0>;
// assigned-clock-rates = <3072000>;
// sound-name-prefix = "DMIC1";
// status = "okay";
// tegra_dspk1: dspk@2905000 {
// compatible = "nvidia,tegra186-dspk";
// reg = <0x0 0x2905000 0x0 0x100>;
// clocks = <&bpmp_clks TEGRA194_CLK_DSPK1>,
// <&bpmp_clks TEGRA194_CLK_SYNC_DSPK1>;
// clock-names = "dspk", "pll_a_out0", "sync_dspk";
// assigned-clocks = <&tegra_car TEGRA194_CLK_DSPK1>;
// sound-name-prefix = "DSPK1";
// status = "okay";
tegra_acsl_audio: acsl_audio {
status = "okay";
hda@3510000 {
status = "okay";
nvidia,model = "NVIDIA Jetson AGX Xavier HDA";
tegra_sound: sound {
status = "okay";
compatible = "nvidia,tegra186-ape";
nvidia-audio-card,name = "NVIDIA Jetson AGX Xavier APE";
nvidia,num-codec-link = <1>;
nvidia,num-clk = <6>;
nvidia,clk-rates = < 270950400 /* PLLA_x11025_RATE */
11289600 /* AUD_MCLK_x11025_RATE */
45158400 /* PLLA_OUT0_x11025_RATE */
45158400 /* AHUB_x11025_RATE */
245760000 /* PLLA_x8000_RATE */
12288000 /* AUD_MCLK_x8000_RATE */
49152000 /* PLLA_OUT0_x8000_RATE */
49152000 >;/* AHUB_x8000_RATE */
nvidia,xbar = <&tegra_axbar>;
clocks = <&bpmp_clks TEGRA194_CLK_PLLA>,
clock-names = "pll_a", "pll_a_out0", "extern1";
assigned-clocks = <&bpmp_clks TEGRA194_CLK_AUD_MCLK>;
assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLA_OUT0>;
nvidia-audio-card,widgets =
"Headphone", "WM Headphone Jack",
"Microphone", "WM Mic",
"Line", "WM Line In Jack",
"Microphone", "WM MICBIAS";
//add
nvidia-audio-card,routing =
"WM Headphone Jack", "WM HPOUTL",
"WM Headphone Jack", "WM HPOUTR",
"WM IN2L", "WM Line In Jack",
"WM IN2R", "WM Line In Jack",
"WM Mic", "WM MICBIAS",
"WM IN1L", "WM Mic",
"WM Headphone", "WM HPOUTL",
"WM Headphone", "WM HPOUTR";
nvidia-audio-card,mclk-fs = <256>;
nvidia,dai-link-1 {
cpu-dai = <&tegra_i2s1>;
codec-dai = <&wm8904_codec>;
cpu-dai-name = "I2S1";
codec-dai-name = "wm8904-hifi";
format = "i2s";
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = "s16_le";
bclk_ratio = <0>;
srate = <48000>;
num-channel = <2>;
ignore_suspend;
name-prefix = "WM";
status = "okay";
tegra_sound_graph: sound_graph {
compatible = "nvidia,tegra186-audio-graph-card";
* Tegra audio graph card is based on uptream generic audio
* graph sound card. In future there is plan to use this
* as default sound card.
status = "disabled";
dais = /* ADMAIF (FE) Ports */
<&admaif1_port>, <&admaif2_port>, <&admaif3_port>,
<&admaif4_port>, <&admaif5_port>, <&admaif6_port>,
<&admaif7_port>, <&admaif8_port>, <&admaif9_port>,
<&admaif10_port>, <&admaif11_port>, <&admaif12_port>,
<&admaif13_port>, <&admaif14_port>, <&admaif15_port>,
<&admaif16_port>, <&admaif17_port>, <&admaif18_port>,
<&admaif19_port>, <&admaif20_port>,
/* ADSP (FE) Ports */
<&adsp_pcm1_port>, <&adsp_pcm2_port>,
<&adsp_compr1_port>, <&adsp_compr2_port>,
/* XBAR I/O ports */
<&xbar_i2s1_port>, <&xbar_i2s2_port>, <&xbar_i2s3_port>,
<&xbar_i2s4_port>, <&xbar_i2s5_port>, <&xbar_i2s6_port>,
<&xbar_dmic1_port>, <&xbar_dmic2_port>,
<&xbar_dmic3_port>, <&xbar_dmic4_port>,
<&xbar_dspk1_port>, <&xbar_dspk2_port>,
/* XBAR HW accelerator ports */
<&xbar_sfc1_in_port>, <&xbar_sfc2_in_port>,
<&xbar_sfc3_in_port>, <&xbar_sfc4_in_port>,
<&xbar_mvc1_in_port>, <&xbar_mvc2_in_port>,
<&xbar_afc1_in_port>, <&xbar_afc2_in_port>,
<&xbar_afc3_in_port>, <&xbar_afc4_in_port>,
<&xbar_afc5_in_port>, <&xbar_afc6_in_port>,
<&xbar_asrc_in1_port>, <&xbar_asrc_in2_port>,
<&xbar_asrc_in3_port>, <&xbar_asrc_in4_port>,
<&xbar_asrc_in5_port>, <&xbar_asrc_in6_port>,
<&xbar_asrc_in7_port>, <&xbar_arad_port>,
<&xbar_mixer_in1_port>, <&xbar_mixer_in2_port>,
<&xbar_mixer_in3_port>, <&xbar_mixer_in4_port>,
<&xbar_mixer_in5_port>, <&xbar_mixer_in6_port>,
<&xbar_mixer_in7_port>, <&xbar_mixer_in8_port>,
<&xbar_mixer_in9_port>, <&xbar_mixer_in10_port>,
<&xbar_ope1_in_port>,
<&xbar_amx1_in1_port>, <&xbar_amx1_in2_port>,
<&xbar_amx1_in3_port>, <&xbar_amx1_in4_port>,
<&xbar_amx2_in1_port>, <&xbar_amx2_in2_port>,
<&xbar_amx2_in3_port>, <&xbar_amx2_in4_port>,
<&xbar_amx3_in1_port>, <&xbar_amx3_in2_port>,
<&xbar_amx3_in3_port>, <&xbar_amx3_in4_port>,
<&xbar_amx4_in1_port>, <&xbar_amx4_in2_port>,
<&xbar_amx4_in3_port>, <&xbar_amx4_in4_port>,
<&xbar_adx1_in_port>, <&xbar_adx2_in_port>,
<&xbar_adx3_in_port>, <&xbar_adx4_in_port>,
/* BE I/O Ports */
<&i2s1_port>, <&i2s2_port>, <&i2s3_port>,
<&i2s4_port>, <&i2s5_port>, <&i2s6_port>,
<&dmic1_port>, <&dmic2_port>, <&dmic3_port>,
<&dmic4_port>,
<&dspk1_port>, <&dspk2_port>,
/* BE HW accelerator ports */
<&sfc1_out_port>, <&sfc2_out_port>,
<&sfc3_out_port>, <&sfc4_out_port>,
<&mvc1_out_port>, <&mvc2_out_port>,
<&afc1_out_port>, <&afc2_out_port>,
<&afc3_out_port>, <&afc4_out_port>,
<&afc5_out_port>, <&afc6_out_port>,
<&asrc_out1_port>, <&asrc_out2_port>,
<&asrc_out3_port>, <&asrc_out4_port>,
<&asrc_out5_port>, <&asrc_out6_port>,
<&mixer_out1_port>, <&mixer_out2_port>,
<&mixer_out3_port>, <&mixer_out4_port>,
<&mixer_out5_port>,
<&ope1_out_port>,
<&amx1_out_port>, <&amx2_out_port>,
<&amx3_out_port>, <&amx4_out_port>,
<&adx1_out1_port>, <&adx1_out2_port>,
<&adx1_out3_port>, <&adx1_out4_port>,
<&adx2_out1_port>, <&adx2_out2_port>,
<&adx2_out3_port>, <&adx2_out4_port>,
<&adx3_out1_port>, <&adx3_out2_port>,
<&adx3_out3_port>, <&adx3_out4_port>,
<&adx4_out1_port>, <&adx4_out2_port>,
<&adx4_out3_port>, <&adx4_out4_port>,
/* ADSP related ports */
<&adsp_admaif1_port>, <&adsp_admaif2_port>,
<&adsp_admaif3_port>, <&adsp_admaif4_port>,
<&adsp_admaif5_port>, <&adsp_admaif6_port>,
<&adsp_admaif7_port>, <&adsp_admaif8_port>,
<&adsp_admaif9_port>, <&adsp_admaif10_port>,
<&adsp_admaif11_port>, <&adsp_admaif12_port>,
<&adsp_admaif13_port>, <&adsp_admaif14_port>,
<&adsp_admaif15_port>, <&adsp_admaif16_port>,
<&adsp_admaif17_port>, <&adsp_admaif18_port>,
<&adsp_admaif19_port>, <&adsp_admaif20_port>,
<&admaif1_codec_port>, <&admaif2_codec_port>,
<&admaif3_codec_port>, <&admaif4_codec_port>,
<&admaif5_codec_port>, <&admaif6_codec_port>,
<&admaif7_codec_port>, <&admaif8_codec_port>,
<&admaif9_codec_port>, <&admaif10_codec_port>,
<&admaif11_codec_port>, <&admaif12_codec_port>,
<&admaif13_codec_port>, <&admaif14_codec_port>,
<&admaif15_codec_port>, <&admaif16_codec_port>,
<&admaif17_codec_port>, <&admaif18_codec_port>,
<&admaif19_codec_port>, <&admaif20_codec_port>;
label = "NVIDIA Jetson AGX Xavier APE";
clock-names = "pll_a", "plla_out0";
widgets = "Headphone", "WM Headphone Jack",
routing = "WM Headphone Jack", "WM HPOUTL",
"WM IN1L", "WM Mic";
* For codec2codec based DAI link design this is required.
* For DPCM based design, this is optional and instead
* it will be picked from codec port node.
mclk-fs = <256>;
* Default config for all I2S dai links are
* format = "i2s", bitclock-slave, frame-slave,
* bitclock-noninversion, frame-noninversion,
* Any change from default needs override on
* platform specific files.
/* Override with Codec entries */
&i2s1_to_codec {
// link-name = "rt5658-playback";
bitclock-master;
frame-master;
codec {
sound-dai = <&wm8904_codec 0>;
prefix = "WM";
hdr40_snd_link_i2s: &i2s2_to_codec { };
/* Override with BT SCO entries */
&i2s4_to_codec {
format = "dsp_a";
bitclock-inversion;
/* Audio graph related bindings */
&i2s1_dap_ep {
remote-endpoint = <&wm8904_ep>;
&i2s4_dap_ep {
dai-format = "dsp_a";
bitclock-inversion;
hdr40_snd_i2s_dap_ep: &i2s2_dap_ep { };
