How to modify /etc/resolv.conf nameserver?
Now the default is 127.0.0.53,I want to change it to 114.114.114.114.
when I edit and modify directly,restart and restore to the previous IP.
try to change the file in /etc/resolvconf/resolf.conf.d/head
Regards
Thank you for reply
After I tried it,open the head file,The display is as follows:
Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
DO NOT EDIT THIS FILE BY HAND – YOUR CHANGES WILL BE OVERWRITTEN
127.0.0.53 is the systemd-resolved stub resolver.
run “systemd-resolve --status” to see details about the actual nameservers.
After that, I execute “systemd-resolve --status”,show:
Global
DNSSEC NTA: 10.in-addr.arpa
16.172.in-addr.arpa
168.192.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
lines 1-23…skipping…
Global
16.172.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lines 1-24…skipping…
Global
16.172.in-addr.arpa
17.172.in-addr.arpa
18.172.in-addr.arpa
19.172.in-addr.arpa
20.172.in-addr.arpa
21.172.in-addr.arpa
22.172.in-addr.arpa
23.172.in-addr.arpa
24.172.in-addr.arpa
25.172.in-addr.arpa
26.172.in-addr.arpa
27.172.in-addr.arpa
28.172.in-addr.arpa
29.172.in-addr.arpa
30.172.in-addr.arpa
31.172.in-addr.arpa
corp
d.f.ip6.arpa
home
internal
intranet
lan
local
private
test
Link 8 (wlan0)
Current Scopes: none
LLMNR setting: yes
MulticastDNS setting: no
DNSSEC setting: no
DNSSEC supported: no
Link 7 (usb0)
LLMNR setting: yes
DNSSEC setting: no
Link 6 (rndis0)
LLMNR setting: yes
DNSSEC setting: no
Link 5 (l4tbr0)
LLMNR setting: yes
DNSSEC setting: no
Link 4 (eth1)
LLMNR setting: yes
DNSSEC setting: no
Link 3 (eth0)
Current Scopes: DNS
LLMNR setting: yes
DNSSEC setting: no
DNS Servers: 192.168.2.10
DNS Domain: ~.
Link 2 (dummy0)
LLMNR setting: yes
DNSSEC setting: no
DNSSEC supported:
but I can’t find anything to change
This may help:
Please take a look.
