How to configure the Bluetooth module in slave mode and skip the pin code pairing so that the mobile phone can receive and connect to the device directly?
Our device does not have keyboard and mouse, how to turn on the device to let the Bluetooth module into the pairing state.And you can connect it directly from your phone?
thanks。
Hi 243953617,
The device doesn’t have keyboard/mouse? How do you use the Jetson-NX platform?
The bluetooth connection need via terminal command line or Desktop GUI.
Hi carolyuu
We use it as a routing device, with only one network cable connected to the outside.But hopefully you can connect it via Bluetooth on your phone to view and configure some parameters.
It seems not related to an issue on jetson. You can chck some linux community for solution.
