Hello.
I’m trying to get Jetson Xavier NX to display the test patterns generated by Ultra96 via MIPI CSI-2.
The generated test patterns can be viewed on the SoC FPGA board, but for some reason not on the Jetson Xavier NX.
I want to find out the reason for not being able to display test patterns on Jetson Xavier NX via MIPI CSI-2, implement some countermeasures, and then display the test pattern.
Can someone please help?
Trial content
- I created the design of Ultra96 with reference to the following page.
https://www.hackster.io/344011/ultra96-csi-2-video-output-to-raspberry-pi-camera-input-e6dfa0 - I changed the MIPI output data type of the above design from RGB888 to RAW10.
This change was due to a desire to have the Ultra 96 mimic the Raspberry Pi camera.
I also changed the output resolution from 1280x720 to 1920x1080.
This design can then be viewed on the SoC FPGA board from the Ultra96 via MIPI CSI-2. - I loaded the above design into Ultra96, and ran I2C communication response processing software that imitates the Raspberry Pi camera.
- When I start the Jetson Xavier NX, Ultra96 is recognized as a Raspberry Pi camera and a “/dev/video0” file is created.
I used JetPack 4.5.1 for the Jetson Xavier NX. - To check the operation I execulted the following command, but it didn’t work.
Execution command
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0,sensor_mode=2 --stream-mmap
Kernel log
Jun 7 11:34:14 jetson-xavier-nx kernel: [ 652.374157] tegra194-vi5 15c10000.vi: no reply from camera processor
Jun 7 11:34:14 jetson-xavier-nx kernel: [ 652.374322] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
Jun 7 11:34:14 jetson-xavier-nx kernel: [ 652.374536] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
Jun 7 11:34:14 jetson-xavier-nx kernel: [ 652.377593] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
Jun 7 11:34:17 jetson-xavier-nx kernel: [ 654.934149] tegra194-vi5 15c10000.vi: no reply from camera processor
Jun 7 11:34:17 jetson-xavier-nx kernel: [ 654.934342] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
Jun 7 11:34:17 jetson-xavier-nx kernel: [ 654.934633] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
Jun 7 11:34:17 jetson-xavier-nx kernel: [ 654.940236] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
Jun 7 11:34:19 jetson-xavier-nx kernel: [ 657.494140] tegra194-vi5 15c10000.vi: no reply from camera processor
Jun 7 11:34:19 jetson-xavier-nx kernel: [ 657.494305] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
Jun 7 11:34:19 jetson-xavier-nx kernel: [ 657.494592] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
Jun 7 11:34:19 jetson-xavier-nx kernel: [ 657.497617] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
- I wanted to know the operating status, so I executed the following command to get the trace information, but I don’t understand the contents.
Execution command
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
Trace information
# tracer: nop
# entries-in-buffer/entries-written: 3395/3395 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-9325 [001] .... 649.733378: tegra_channel_open: vi-output, imx219 9-0010
v4l2-ctl-9325 [003] .... 649.735618: tegra_channel_set_power: imx219 9-0010 : 0x1
v4l2-ctl-9325 [003] .... 649.735638: camera_common_s_power: status : 0x1
v4l2-ctl-9325 [003] .... 649.758835: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
v4l2-ctl-9325 [003] .... 649.758841: csi_s_power: enable : 0x1
v4l2-ctl-9325 [005] .... 649.767522: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
v4l2-ctl-9325 [003] .... 649.776644: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-9325 [004] .... 649.780124: tegra_channel_set_stream: 15a00000.nvcsi--2 : 0x1
v4l2-ctl-9325 [004] .... 649.780129: csi_s_stream: enable : 0x1
v4l2-ctl-9325 [004] .... 649.780168: tegra_channel_set_stream: imx219 9-0010 : 0x1
kworker/0:0-4 [000] .... 649.786218: rtos_queue_peek_from_isr_failed: tstamp:20719029409 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 649.786223: rtcpu_start: tstamp:20719032354
kworker/0:0-4 [000] .... 649.786226: rtos_queue_send_from_isr_failed: tstamp:20719046486 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 649.786227: rtos_queue_send_from_isr_failed: tstamp:20719046639 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 649.786228: rtos_queue_send_from_isr_failed: tstamp:20719046789 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 649.786229: rtos_queue_send_from_isr_failed: tstamp:20719046935 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 649.786230: rtos_queue_send_from_isr_failed: tstamp:20719047084 queue:0x0bcbc160
kworker/0:0-4 [000] .... 649.786232: rtcpu_string: tstamp:20719047517 id:0x04010000 str:"Configuring VI GoS.
kworker/0:0-4 [000] .... 649.786248: rtcpu_string: tstamp:20719047695 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:0-4 [000] .... 649.786253: rtcpu_string: tstamp:20719047952 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:0-4 [000] .... 649.786258: rtcpu_string: tstamp:20719048224 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:0-4 [000] .... 649.786263: rtcpu_string: tstamp:20719048456 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:0-4 [000] .... 649.786268: rtcpu_string: tstamp:20719048688 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:0-4 [000] .... 649.786272: rtcpu_string: tstamp:20719048920 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:0-4 [000] .... 649.786277: rtcpu_string: tstamp:20719057698 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol vers"
kworker/0:0-4 [000] .... 649.786279: rtcpu_string: tstamp:20719057817 id:0x04010000 str:"on 2.2
kworker/0:0-4 [000] .... 649.786284: rtos_queue_send_from_isr_failed: tstamp:20719183076 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 649.786285: rtos_queue_send_from_isr_failed: tstamp:20719183246 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 649.786286: rtos_queue_send_from_isr_failed: tstamp:20719183400 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 649.786287: rtos_queue_send_from_isr_failed: tstamp:20719183548 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 649.786288: rtos_queue_send_from_isr_failed: tstamp:20719183695 queue:0x0bcbc160
kworker/0:0-4 [000] .... 649.786289: rtcpu_string: tstamp:20719184567 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:0-4 [000] .... 649.786294: rtos_queue_send_from_isr_failed: tstamp:20719294522 queue:0x0bcb41f8
kworker/0:0-4 [000] .... 649.786295: rtos_queue_send_from_isr_failed: tstamp:20719294671 queue:0x0bcb8a60
kworker/0:0-4 [000] .... 649.786296: rtos_queue_send_from_isr_failed: tstamp:20719294823 queue:0x0bcba5e0
kworker/0:0-4 [000] .... 649.786297: rtos_queue_send_from_isr_failed: tstamp:20719294969 queue:0x0bcbb3a0
kworker/0:0-4 [000] .... 649.786298: rtos_queue_send_from_isr_failed: tstamp:20719295116 queue:0x0bcbc160
kworker/0:0-4 [000] .... 649.842195: rtcpu_vinotify_event: tstamp:20719512969 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18768852128 data:0x10000000
kworker/0:0-4 [000] .... 649.842200: rtcpu_vinotify_event: tstamp:20719513136 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18768860512 data:0x31000001
kworker/0:0-4 [000] .... 649.842201: rtcpu_vinotify_event: tstamp:20719513298 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:18768862688 data:0x07020001
kworker/0:0-4 [000] .... 649.842202: rtcpu_vinotify_event: tstamp:20719513435 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18768896576 data:0x10000000
kworker/0:0-4 [000] .... 649.842203: rtcpu_vinotify_event: tstamp:20719513596 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:18768904992 data:0x31000002
kworker/0:0-4 [000] .... 649.842211: rtcpu_vinotify_event: tstamp:20720598303 tag:FS channel:0x00 frame:0 vi_tstamp:20720164827 data:0x00000010
kworker/0:0-4 [000] .... 649.842212: rtcpu_vinotify_event: tstamp:20720598469 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:20720164830 data:0x00000000
kworker/0:0-4 [000] .... 649.842213: rtcpu_vinotify_event: tstamp:20720598609 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:20720164910 data:0x00000001
kworker/0:0-4 [000] .... 649.842214: rtcpu_vinotify_event: tstamp:20720598767 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:18800197088 data:0x08020001
kworker/0:0-4 [000] .... 649.842215: rtcpu_vinotify_event: tstamp:20720819842 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:20720814577 data:0x04370002
kworker/0:0-4 [000] .... 649.842216: rtcpu_vinotify_event: tstamp:20720820000 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:20720814604 data:0x00000000
kworker/0:0-4 [000] .... 649.842217: rtcpu_vinotify_event: tstamp:20720820139 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:18820979936 data:0x02020001
kworker/0:0-4 [000] .... 649.842218: rtcpu_vinotify_event: tstamp:20720820296 tag:FE channel:0x00 frame:0 vi_tstamp:20720814657 data:0x00000020
kworker/0:0-4 [000] .... 649.842218: rtcpu_vinotify_event: tstamp:20720820436 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:20720814660 data:0x00000000
kworker/0:0-4 [000] .... 649.842219: rtcpu_vinotify_event: tstamp:20720820590 tag:FS channel:0x00 frame:0 vi_tstamp:20720814697 data:0x00000010
kworker/0:0-4 [000] .... 649.842220: rtcpu_vinotify_event: tstamp:20720820730 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:20720814701 data:0x00000000
kworker/0:0-4 [000] .... 649.898154: rtcpu_vinotify_event: tstamp:20721357670 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:20720814854 data:0x00000001
kworker/0:0-4 [000] .... 649.898159: rtcpu_vinotify_event: tstamp:20721357808 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:18821026912 data:0x08020001
kworker/0:0-4 [000] .... 649.898161: rtcpu_vinotify_error: tstamp:20721469942 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20721466250 data:0x00000569
kworker/0:0-4 [000] .... 649.898163: rtcpu_vinotify_event: tstamp:20721900064 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:20721465973 data:0x04370002
kworker/0:0-4 [000] .... 649.898164: rtcpu_vinotify_event: tstamp:20721900218 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:20721466001 data:0x00000000
kworker/0:0-4 [000] .... 649.898165: rtcpu_vinotify_event: tstamp:20721900376 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:18841824672 data:0x02020001
kworker/0:0-4 [000] .... 649.898166: rtcpu_vinotify_event: tstamp:20721900513 tag:FE channel:0x00 frame:0 vi_tstamp:20721466052 data:0x00000020
kworker/0:0-4 [000] .... 649.898167: rtcpu_vinotify_event: tstamp:20721900676 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:20721466055 data:0x00000000
kworker/0:0-4 [000] .... 649.898168: rtcpu_vinotify_event: tstamp:20721900812 tag:FS channel:0x00 frame:0 vi_tstamp:20721466093 data:0x00000010
kworker/0:0-4 [000] .... 649.898170: rtcpu_vinotify_event: tstamp:20721900968 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20721466250 data:0x00000569
kworker/0:0-4 [000] .... 649.898171: rtcpu_vinotify_error: tstamp:20722120467 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20722117646 data:0x00000569
kworker/0:0-4 [000] .... 649.898172: rtcpu_vinotify_event: tstamp:20722443051 tag:FE channel:0x00 frame:0 vi_tstamp:20722117448 data:0x00000020
kworker/0:0-4 [000] .... 649.898173: rtcpu_vinotify_event: tstamp:20722443211 tag:FS channel:0x00 frame:0 vi_tstamp:20722117488 data:0x00000010
kworker/0:0-4 [000] .... 649.898174: rtcpu_vinotify_event: tstamp:20722443347 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20722117646 data:0x00000569
kworker/0:0-4 [000] .... 649.898175: rtcpu_vinotify_error: tstamp:20722771865 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20722769041 data:0x00000569
kworker/0:0-4 [000] .... 649.954152: rtcpu_vinotify_event: tstamp:20722985240 tag:FE channel:0x00 frame:0 vi_tstamp:20722768843 data:0x00000020
kworker/0:0-4 [000] .... 649.954155: rtcpu_vinotify_event: tstamp:20722985382 tag:FS channel:0x00 frame:0 vi_tstamp:20722768883 data:0x00000010
kworker/0:0-4 [000] .... 649.954157: rtcpu_vinotify_event: tstamp:20722985541 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20722769041 data:0x00000569
kworker/0:0-4 [000] .... 649.954158: rtcpu_vinotify_error: tstamp:20723423299 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20723420436 data:0x00000569
kworker/0:0-4 [000] .... 649.954160: rtcpu_vinotify_event: tstamp:20723423686 tag:FE channel:0x00 frame:0 vi_tstamp:20723420238 data:0x00000020
kworker/0:0-4 [000] .... 649.954161: rtcpu_vinotify_event: tstamp:20723962012 tag:FS channel:0x00 frame:0 vi_tstamp:20723420279 data:0x00000010
kworker/0:0-4 [000] .... 649.954162: rtcpu_vinotify_event: tstamp:20723962149 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20723420436 data:0x00000569
kworker/0:0-4 [000] .... 649.954165: rtos_queue_peek_from_isr_failed: tstamp:20724029763 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 649.954166: rtcpu_vinotify_error: tstamp:20724074661 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20724071831 data:0x00000569
kworker/0:0-4 [000] .... 649.954168: rtcpu_vinotify_event: tstamp:20724504199 tag:FE channel:0x00 frame:0 vi_tstamp:20724071633 data:0x00000020
kworker/0:0-4 [000] .... 649.954169: rtcpu_vinotify_event: tstamp:20724504335 tag:FS channel:0x00 frame:0 vi_tstamp:20724071674 data:0x00000010
kworker/0:0-4 [000] .... 649.954170: rtcpu_vinotify_event: tstamp:20724504496 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20724071831 data:0x00000569
kworker/0:0-4 [000] .... 649.954171: rtcpu_vinotify_error: tstamp:20724726039 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20724723227 data:0x00000569
kworker/0:0-4 [000] .... 650.010155: rtcpu_vinotify_event: tstamp:20725047181 tag:FE channel:0x00 frame:0 vi_tstamp:20724723029 data:0x00000020
kworker/0:0-4 [000] .... 650.010158: rtcpu_vinotify_event: tstamp:20725047341 tag:FS channel:0x00 frame:0 vi_tstamp:20724723068 data:0x00000010
kworker/0:0-4 [000] .... 650.010159: rtcpu_vinotify_event: tstamp:20725047476 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20724723227 data:0x00000569
kworker/0:0-4 [000] .... 650.010161: rtcpu_vinotify_error: tstamp:20725377438 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20725374622 data:0x00000569
kworker/0:0-4 [000] .... 650.010162: rtcpu_vinotify_event: tstamp:20725589370 tag:FE channel:0x00 frame:0 vi_tstamp:20725374424 data:0x00000020
kworker/0:0-4 [000] .... 650.010163: rtcpu_vinotify_event: tstamp:20725589505 tag:FS channel:0x00 frame:0 vi_tstamp:20725374465 data:0x00000010
kworker/0:0-4 [000] .... 650.010164: rtcpu_vinotify_event: tstamp:20725589659 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20725374622 data:0x00000569
kworker/0:0-4 [000] .... 650.010165: rtcpu_vinotify_error: tstamp:20726028832 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20726026017 data:0x00000569
kworker/0:0-4 [000] .... 650.010167: rtcpu_vinotify_event: tstamp:20726132360 tag:FE channel:0x00 frame:0 vi_tstamp:20726025819 data:0x00000020
kworker/0:0-4 [000] .... 650.010168: rtcpu_vinotify_event: tstamp:20726132517 tag:FS channel:0x00 frame:0 vi_tstamp:20726025859 data:0x00000010
kworker/0:0-4 [000] .... 650.010169: rtcpu_vinotify_event: tstamp:20726132652 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20726026017 data:0x00000569
kworker/0:0-4 [000] .... 650.066133: rtcpu_vinotify_error: tstamp:20726680270 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20726677412 data:0x00000569
kworker/0:0-4 [000] .... 650.066136: rtcpu_vinotify_event: tstamp:20726680662 tag:FE channel:0x00 frame:0 vi_tstamp:20726677215 data:0x00000020
kworker/0:0-4 [000] .... 650.066138: rtcpu_vinotify_event: tstamp:20726680802 tag:FS channel:0x00 frame:0 vi_tstamp:20726677255 data:0x00000010
kworker/0:0-4 [000] .... 650.066139: rtcpu_vinotify_event: tstamp:20727216774 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20726677412 data:0x00000569
kworker/0:0-4 [000] .... 650.066140: rtcpu_vinotify_error: tstamp:20727331626 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20727328808 data:0x00000569
kworker/0:0-4 [000] .... 650.066141: rtcpu_vinotify_event: tstamp:20727759753 tag:FE channel:0x00 frame:0 vi_tstamp:20727328610 data:0x00000020
kworker/0:0-4 [000] .... 650.066142: rtcpu_vinotify_event: tstamp:20727759908 tag:FS channel:0x00 frame:0 vi_tstamp:20727328651 data:0x00000010
kworker/0:0-4 [000] .... 650.066143: rtcpu_vinotify_event: tstamp:20727760044 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20727328808 data:0x00000569
kworker/0:0-4 [000] .... 650.066145: rtcpu_vinotify_error: tstamp:20727983019 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20727980203 data:0x00000569
kworker/0:0-4 [000] .... 650.122170: rtcpu_vinotify_event: tstamp:20728301939 tag:FE channel:0x00 frame:0 vi_tstamp:20727980006 data:0x00000020
kworker/0:0-4 [000] .... 650.122174: rtcpu_vinotify_event: tstamp:20728302078 tag:FS channel:0x00 frame:0 vi_tstamp:20727980046 data:0x00000010
kworker/0:0-4 [000] .... 650.122175: rtcpu_vinotify_event: tstamp:20728302237 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20727980203 data:0x00000569
kworker/0:0-4 [000] .... 650.122177: rtcpu_vinotify_error: tstamp:20728634414 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20728631598 data:0x00000569
kworker/0:0-4 [000] .... 650.122178: rtcpu_vinotify_event: tstamp:20728844929 tag:FE channel:0x00 frame:0 vi_tstamp:20728631401 data:0x00000020
kworker/0:0-4 [000] .... 650.122179: rtcpu_vinotify_event: tstamp:20728845086 tag:FS channel:0x00 frame:0 vi_tstamp:20728631441 data:0x00000010
kworker/0:0-4 [000] .... 650.122180: rtcpu_vinotify_event: tstamp:20728845222 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20728631598 data:0x00000569
kworker/0:0-4 [000] .... 650.122183: rtos_queue_peek_from_isr_failed: tstamp:20729029766 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 650.122184: rtcpu_vinotify_error: tstamp:20729285810 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20729282993 data:0x00000569
kworker/0:0-4 [000] .... 650.122186: rtcpu_vinotify_event: tstamp:20729387115 tag:FE channel:0x00 frame:0 vi_tstamp:20729282796 data:0x00000020
kworker/0:0-4 [000] .... 650.122187: rtcpu_vinotify_event: tstamp:20729387250 tag:FS channel:0x00 frame:0 vi_tstamp:20729282837 data:0x00000010
kworker/0:0-4 [000] .... 650.122188: rtcpu_vinotify_event: tstamp:20729387406 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20729282993 data:0x00000569
kworker/0:0-4 [000] .... 650.122189: rtcpu_vinotify_error: tstamp:20729937395 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20729934389 data:0x00000569
kworker/0:0-4 [000] .... 650.122190: rtcpu_vinotify_event: tstamp:20729937783 tag:FE channel:0x00 frame:0 vi_tstamp:20729934191 data:0x00000020
kworker/0:0-4 [000] .... 650.122191: rtcpu_vinotify_event: tstamp:20729937941 tag:FS channel:0x00 frame:0 vi_tstamp:20729934232 data:0x00000010
kworker/0:0-4 [000] .... 650.122192: rtcpu_vinotify_event: tstamp:20729938077 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20729934389 data:0x00000569
kworker/0:0-4 [000] .... 650.178150: rtcpu_vinotify_error: tstamp:20730588601 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20730585785 data:0x00000569
kworker/0:0-4 [000] .... 650.178153: rtcpu_vinotify_event: tstamp:20730634715 tag:FE channel:0x00 frame:0 vi_tstamp:20730585587 data:0x00000020
kworker/0:0-4 [000] .... 650.178155: rtcpu_vinotify_event: tstamp:20730634851 tag:FS channel:0x00 frame:0 vi_tstamp:20730585627 data:0x00000010
kworker/0:0-4 [000] .... 650.178156: rtcpu_vinotify_event: tstamp:20730635008 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20730585785 data:0x00000569
kworker/0:0-4 [000] .... 650.178158: rtcpu_vinotify_error: tstamp:20731239999 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20731237179 data:0x00000569
kworker/0:0-4 [000] .... 650.178159: rtcpu_vinotify_event: tstamp:20731720408 tag:FE channel:0x00 frame:0 vi_tstamp:20731236982 data:0x00000020
kworker/0:0-4 [000] .... 650.178160: rtcpu_vinotify_event: tstamp:20731720568 tag:FS channel:0x00 frame:0 vi_tstamp:20731237021 data:0x00000010
kworker/0:0-4 [000] .... 650.178161: rtcpu_vinotify_event: tstamp:20731720708 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20731237179 data:0x00000569
kworker/0:0-4 [000] .... 650.234141: rtcpu_vinotify_error: tstamp:20731891394 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20731888575 data:0x00000569
kworker/0:0-4 [000] .... 650.234144: rtcpu_vinotify_event: tstamp:20732262599 tag:FE channel:0x00 frame:0 vi_tstamp:20731888377 data:0x00000020
kworker/0:0-4 [000] .... 650.234145: rtcpu_vinotify_event: tstamp:20732262734 tag:FS channel:0x00 frame:0 vi_tstamp:20731888418 data:0x00000010
kworker/0:0-4 [000] .... 650.234147: rtcpu_vinotify_event: tstamp:20732262889 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20731888575 data:0x00000569
kworker/0:0-4 [000] .... 650.234148: rtcpu_vinotify_error: tstamp:20732542784 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20732539970 data:0x00000569
kworker/0:0-4 [000] .... 650.234149: rtcpu_vinotify_event: tstamp:20732805593 tag:FE channel:0x00 frame:0 vi_tstamp:20732539773 data:0x00000020
kworker/0:0-4 [000] .... 650.234150: rtcpu_vinotify_event: tstamp:20732805749 tag:FS channel:0x00 frame:0 vi_tstamp:20732539812 data:0x00000010
kworker/0:0-4 [000] .... 650.234151: rtcpu_vinotify_event: tstamp:20732805886 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20732539970 data:0x00000569
kworker/0:0-4 [000] .... 650.234152: rtcpu_vinotify_error: tstamp:20733194182 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20733191366 data:0x00000569
kworker/0:0-4 [000] .... 650.234153: rtcpu_vinotify_event: tstamp:20733347783 tag:FE channel:0x00 frame:0 vi_tstamp:20733191168 data:0x00000020
kworker/0:0-4 [000] .... 650.234155: rtcpu_vinotify_event: tstamp:20733347919 tag:FS channel:0x00 frame:0 vi_tstamp:20733191208 data:0x00000010
kworker/0:0-4 [000] .... 650.234156: rtcpu_vinotify_event: tstamp:20733348076 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20733191366 data:0x00000569
kworker/0:0-4 [000] .... 650.290163: rtcpu_vinotify_error: tstamp:20733845623 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20733842760 data:0x00000569
kworker/0:0-4 [000] .... 650.290166: rtcpu_vinotify_event: tstamp:20733846013 tag:FE channel:0x00 frame:0 vi_tstamp:20733842563 data:0x00000020
kworker/0:0-4 [000] .... 650.290194: rtos_queue_peek_from_isr_failed: tstamp:20734029762 queue:0x0bcbcf78
kworker/0:0-4 [000] .... 650.290196: rtcpu_vinotify_event: tstamp:20734378543 tag:FS channel:0x00 frame:0 vi_tstamp:20733842603 data:0x00000010
kworker/0:0-4 [000] .... 650.290197: rtcpu_vinotify_event: tstamp:20734378683 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20733842760 data:0x00000569
kworker/0:0-4 [000] .... 650.290199: rtcpu_vinotify_error: tstamp:20734496974 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20734494156 data:0x00000569
kworker/0:0-4 [000] .... 650.290200: rtcpu_vinotify_event: tstamp:20734921524 tag:FE channel:0x00 frame:0 vi_tstamp:20734493958 data:0x00000020
kworker/0:0-4 [000] .... 650.290201: rtcpu_vinotify_event: tstamp:20734921660 tag:FS channel:0x00 frame:0 vi_tstamp:20734493999 data:0x00000010
kworker/0:0-4 [000] .... 650.290202: rtcpu_vinotify_event: tstamp:20734921817 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20734494156 data:0x00000569
kworker/0:0-4 [000] .... 650.290203: rtcpu_vinotify_error: tstamp:20735148369 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20735145552 data:0x00000569
kworker/0:0-4 [000] .... 650.346145: rtcpu_vinotify_event: tstamp:20735463709 tag:FE channel:0x00 frame:0 vi_tstamp:20735145354 data:0x00000020
kworker/0:0-4 [000] .... 650.346156: rtcpu_vinotify_event: tstamp:20735463866 tag:FS channel:0x00 frame:0 vi_tstamp:20735145394 data:0x00000010
kworker/0:0-4 [000] .... 650.346157: rtcpu_vinotify_event: tstamp:20735464002 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20735145552 data:0x00000569
kworker/0:0-4 [000] .... 650.346159: rtcpu_vinotify_error: tstamp:20735799763 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20735796947 data:0x00000569
kworker/0:0-4 [000] .... 650.346160: rtcpu_vinotify_event: tstamp:20736005900 tag:FE channel:0x00 frame:0 vi_tstamp:20735796749 data:0x00000020
kworker/0:0-4 [000] .... 650.346161: rtcpu_vinotify_event: tstamp:20736006035 tag:FS channel:0x00 frame:0 vi_tstamp:20735796790 data:0x00000010
kworker/0:0-4 [000] .... 650.346162: rtcpu_vinotify_event: tstamp:20736006192 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20735796947 data:0x00000569
kworker/0:0-4 [000] .... 650.346164: rtcpu_vinotify_error: tstamp:20736451160 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20736448342 data:0x00000569
kworker/0:0-4 [000] .... 650.346165: rtcpu_vinotify_event: tstamp:20736548888 tag:FE channel:0x00 frame:0 vi_tstamp:20736448144 data:0x00000020
kworker/0:0-4 [000] .... 650.346166: rtcpu_vinotify_event: tstamp:20736549043 tag:FS channel:0x00 frame:0 vi_tstamp:20736448186 data:0x00000010
kworker/0:0-4 [000] .... 650.346200: rtcpu_vinotify_event: tstamp:20736549180 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20736448342 data:0x00000569
kworker/0:0-4 [000] .... 650.402239: rtcpu_vinotify_error: tstamp:20737102603 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20737099737 data:0x00000569
kworker/0:0-4 [000] .... 650.402244: rtcpu_vinotify_event: tstamp:20737102992 tag:FE channel:0x00 frame:0 vi_tstamp:20737099539 data:0x00000020
kworker/0:0-4 [000] .... 650.402246: rtcpu_vinotify_event: tstamp:20737103129 tag:FS channel:0x00 frame:0 vi_tstamp:20737099580 data:0x00000010
kworker/0:0-4 [000] .... 650.402247: rtcpu_vinotify_event: tstamp:20737634103 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20737099737 data:0x00000569
kworker/0:0-4 [000] .... 650.402248: rtcpu_vinotify_error: tstamp:20737753950 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20737751133 data:0x00000569
kworker/0:0-4 [000] .... 650.402249: rtcpu_vinotify_event: tstamp:20738176284 tag:FE channel:0x00 frame:0 vi_tstamp:20737750935 data:0x00000020
kworker/0:0-4 [000] .... 650.402250: rtcpu_vinotify_event: tstamp:20738176440 tag:FS channel:0x00 frame:0 vi_tstamp:20737750974 data:0x00000010
kworker/0:0-4 [000] .... 650.402251: rtcpu_vinotify_event: tstamp:20738176575 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20737751133 data:0x00000569
kworker/0:0-4 [000] .... 650.402252: rtcpu_vinotify_error: tstamp:20738405392 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20738402528 data:0x00000569
kworker/0:0-4 [000] .... 650.402253: rtcpu_vinotify_event: tstamp:20738719274 tag:FE channel:0x00 frame:0 vi_tstamp:20738402330 data:0x00000020
kworker/0:0-4 [000] .... 650.402254: rtcpu_vinotify_event: tstamp:20738719409 tag:FS channel:0x00 frame:0 vi_tstamp:20738402371 data:0x00000010
kworker/0:0-4 [000] .... 650.402255: rtcpu_vinotify_event: tstamp:20738719566 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:20738402528 data:0x00000569
kworker/0:0-4 [000] .... 650.458140: rtos_queue_peek_from_isr_failed: tstamp:20739029763 queue:0x0bcbcf78
If you need more information, please tell me how to obtain it.
Thanks very much!
