I develop a rendering process using DrivePX 2.
I want to implement test data and expected value data on DrivePX 2 in order to demonstrate rendering test as a system. Please tell me whether the following method is possible.
Can SDK (Vibrante / CUDA etc) download jpeg file to FLASH memory or SD card?
Can the SDK tool compare the result of the rendering process with the expected value data?
Dear SteveNV,
Thank you your answer.
I supplement my question.
I found the SDK tool available for downloading files.
1-1. Can you upload jpeg files in Flash memory in the evaluation board (eg DrivePX 2) to the
HOST PC with the SDK tool?
1-2. Please tell me the path and name of the document that describes download and upload methods
2-1. The expected value data to be compared is prepared by the user and downloaded to the
evaluation board.
Can you compare the jpeg file with the rendering result file with SDK?
Unfortunately, I’m not sure what you need from me exactly.
1-1. Can you upload jpeg files in Flash memory in the evaluation board (eg DrivePX 2) to the HOST PC with the SDK tool? ==> You can upload any files to DPX2 via HOST PC ssh tool
Thank you for your update.
I guess you are trying to make a comparator.
It is not possible on DPX2 with DW samples, however you can use Sherlock application on HOST PC.
Please see /usr/local/driveworks-0.3/apps/sherlock in HOST PC.
DriveWorks provides disparity for stereoside please see below link in DPX2. Maybe it does not match with what you expected. Thanks.
/usr/local/driveworks-0.3/doc/nvdwx_html/group__stereo__group.html
I understood that uploading and downloading is possible by HostPC’s function.
I refer to the document about the comparator after DevZone permission.
