How do I flip a single channel with nvvideoconvert?
If I have multiple sources and then flip them through the nvvideoconvert plugin and I only need to flip one of the channels, how should I set it up?
You can try to use it just for one stream before the nvstreammux.
This is theoretically possible. Will it affect the reasoning process that follows?
No. If your trained model can normally recognize the flipped image, the result should be available.
