How do I get the coordinates for Tracker?
I’ve set the DeepStream detection setting to interval=1.
I want to get the tracker coordinates and ID when the object is not detected.
What should I do?
I m using python binginds
Let’s clarify first,
when object not detected
-> you mean object not detected by infer or not tracked in tracker?
That’s included.
When interval=1, only odd (or even) frames are detected, right?
I’d like information on the tracker when the object detection itself is not done.
You can get it by accessing object metadata after tracker component.
and may i get the below information:
**• Hardware Platform :
**• DeepStream Version :
**• JetPack Version if on Jetson
**• TensorRT Version
