How do I get the location information (X, Y or BBox value) of a person in roi-OC1?
**• Hardware Platform : Jetson Nano
**• DeepStream Version : 6.0.1
**• JetPack Version : 4.6.1
I am using nvdsanalytics to build an APP that detects pedestrians within ROI.
I have the following configuration and it’s working fine.
[overcrowding-stream-0]
enable=1
roi-OC1=306;121;915;132;1047;960;15;893
object-threshold=3
#line-width=5
class-id=0
NvDsAnalyticsFrameMeta and NvDsUserMeta don’t seem to have that information.
And additionally, is there a way to adjust the line thickness when roi-OC1 is drawn to the screen?
The app should judge by itself. You can get bbox of every object and you know the ROI, so the application is easy to know whether the object is inside or outside ROI.
No. Currently it is not supported.
