How do I get the wifi signal through the command line?
I want to get the WiFi signal through the command line (iwconfig wlan0).
Reply as follows.
no wireless extensions …
You can try using nmcli. It shows a signal strength of sorts (percentage?).
nmcli device wifi
You can monitor it with
watch nmcli device wifi
Thank you.
Is there any way to know the signal level information of the currently connected WIFI?
Do you mean the strength of the network you’re currently connected to? There should be an asterisk (*) next to the SSID that you’re connected to.
For other options, check out this post. I think wavemon might be close to what you want.
[url]wireless - Is there a tool like wifi analyzer for ubuntu? - Ask Ubuntu
This question doesn’t seem limited to Jetson devices, you might have better luck searching Stack Exchange.
