An example of my question in the title is that nvinfer is referred to as primarygie in a deepstream-app config text file:
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV8.txt
There are multiple cases of this where the reference / header of the plugin in the config file is not the same as the actual name of the plugin. This creates confusion for me as I don’t know what unkown plugins are in configs I find online or in documentation, and vice versa I cannot deduce what the plugin should be called in a config file I create.
An example of the lack of clear documentation here is on the page for nvinfer. The term “primary-gie” is not mentioned anywhere!
Is there something I am missing?
