How do I monitor when configuring OVS Kernel Hardware on ConnectX-6 LX?
In the case of DPU, the telemetry function is available to collect metrics.
When configuring HWOL through ConnectX-6 LX and OVS I want to monitor via ovs eporter and TC Exporter.
However, I can’t see the thresholds for NICs, so if there is an API or solution to get them, please share.
For information about telemetry API you can check the below link:
https://docs.nvidia.com/doca/sdk/telemetry-programming-guide/index.html
Best Regards,
Anatoly
I was under the impression that DOCA Telemetry (DTS) only supported Bluefield, but it turns out that it also supports the ConnectX series.
I will test it, referring to what you said and the information below.
Thank you.
