How do I multiply the corresponding elements of vector A and vector B?
I want to multiply two vector corresponding elements, I use pointers to describe them, and below is a global function I wrote. When I use a small length vector to multiply the corresponding elements, I can get the correct answer, but when the length of the data increases, my result is wrong, I want to know where I am wrong, and is there a good way to achieve my goal?
InputPtr: vector A;
Array: vector B;
Len: total length of the vectors, A and B have the same length.
__global__ void DotMultiply(cuFloatComplex* InputPtr, float* Array, int Len)
	int i = threadIdx.x;
	__shared__ cuFloatComplex s_Input[512];
	__shared__ float s_Array[512];
	if (i < blockDim.x && i + blockDim.x * blockIdx.x < Len)
		s_Input[i] = InputPtr[i + blockDim.x * blockIdx.x];
		s_Array[i] = Array[i + blockDim.x * blockIdx.x];
	else
		s_Input[i].x = 0;
		s_Input[i].y = 0;
		s_Array[i] = 0;
	__syncthreads();
	if (i < blockDim.x)
		s_Input[i].x = s_Input[i].x * s_Array[i];
		s_Input[i].y = s_Input[i].y * s_Array[i];
	__syncthreads();
		InputPtr[i + blockDim.x * blockIdx.x] = s_Input[i];
So you would like to compute a[i]=a[i]*b[i] for i < len in parallel?
I don’t seem to have any trouble with the code you have posted:
# cat t29.cu
#include <cuComplex.h>
#include <iostream>
InputPtr: vector A;
Array: vector B;
        else
                s_Input[i].x = 0;
                s_Input[i].y = 0;
                s_Array[i] = 0;
        __syncthreads();
        if (i < blockDim.x)
        __syncthreads();
const int dlen = 1048575;
int main(){
  cuFloatComplex *di;
  float *da;
  cudaMallocManaged(&di, dlen *sizeof(di[0]));
  cudaMallocManaged(&da, dlen *sizeof(da[0]));
  for (int i = 0; i < dlen; i++) {di[i] = make_cuFloatComplex(1.0f, 2.0f);  da[i] = 2.0f;}
  DotMultiply<<<(dlen+511)/512, 512>>>(di, da, dlen);
  cudaDeviceSynchronize();
  for (int i = 0; i < dlen; i++) if ((di[i].x != 2.0f) || (di[i].y != 4.0f)) std::cout << "mismatch at: " << i << std::endl;
# nvcc -o t29 t29.cu
# compute-sanitizer ./t29
========= COMPUTE-SANITIZER
========= ERROR SUMMARY: 0 errors
If you’re having a problem, it may lie in something you haven’t shown.
That’s weird, but thank you for your answer, I will have another try.
If i use sing this method, would it take more time to compute, or would using shared memory be faster?
