How do I obtain ROS_Camera images directly from python without subscribing to ROS node
I can create a ROS camera using python through;
result, prim = omni.kit.commands.execute(
“ROSBridgeCreateCamera”, path="/ROS_Camera"
prim is the ROS_camera just created. Is it possible to directly obtain the annotations?
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/tutorial_replicator_visualize_groundtruth.html?highlight=depth%20image
this post provide some instructions, but how do I change the camera resolution? and how do I create additional cameras with annotations?
You can get any of the synthetic image data directly via python as buffers.
See: 3. Visualize Synthetic Data — Omniverse Robotics documentation
Is it possible to have multiple viewports?
yes
If you create a second camera prim in the stage via Create->Camera (or the python equivalent)
and assign this camera prim to the second ROS Bridge camera component’s camera_prim_rel=[camera_prim.GetPrim().GetPrimPath()] setting, it will automatically create a second viewport for you.
You can also manually create a second viewport from the Window-> New Viewport Window menu and assign it a different camera prim from the stage
