How do I provide AGX speed to run YOLO-v4
HI!
AGX executes YOLO-v4 more slowly than NVIDIA T4.
AGX takes 140ms to execute one frame, and T4 takes 40ms to execute.
Then I executed “sudo NVPmodel-m 0” at a speed of 80ms.
Is there any other way to make AGX faster? I’ve heard friends say that AGX is stronger than T4.
Please try the following command to maximize the Xavier performance:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
Hi, here’s what I did,
Thanks for the feedback.
We are checking this internally and will share more information with you later.
Please try our sample listed below:
We can get around 57.74 fps on Xavier with Deepstream pipeline.
This is end-to-end performance including camera, inference and recording.
