How do I recover Jetson Nano Network-Manager after purging it?
I purged the Network-Manager from the Jetson Nano, I have tried running these options with no success:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install network-manager
results:
err 1: failed to resolve "ports.ubuntu.com
I can’t use man or man-db because they don’t work and when I run the “unminimize” command it does nothing to help, there is also no interfaces file in the /etc/network directory.
Reason why i purged it:
it was standard practice to delete a program that is giving you problems so I tried to remove it and download it again.
Welcome to the NVIDIA Developer forums. This topic belongs in the Jetson forums. I have moved it over for you.
Tom
Where can I find the jetson forums?
They are located under Autonomous Machines.
Latest Autonomous Machines/Jetson & Embedded Systems topics - NVIDIA Developer Forums
If there is nothing important on the system, then I would suggest just flashing again. NetworkManager has its fingers in a lot of different configurations. The one thing I would consider other than that is to first list some services and their status. This is what a TX2 has:
# systemctl list-units | grep -i network
boinc-client.service        loaded active     running         Berkeley Open Infrastructure Network Computing Client
networkd-dispatcher.service                                                         loaded active     running         Dispatcher daemon for systemd-networkd
networking.service        loaded active     exited          Raise network interfaces
NetworkManager.service                                                              loaded active     running         Network Manager
systemd-resolved.service                                                            loaded active     running         Network Name Resolution
systemd-timesyncd.service                                                           loaded active     running         Network Time Synchronization
ubuntu-fan.service        loaded active     exited          Ubuntu FAN network setup
network-online.target                                                               loaded active     active          Network is Online
network-pre.target        loaded active     active          Network (Pre)
network.target        loaded active     active          Network
nss-lookup.target        loaded active     active          Host and Network Name Lookups
Of all of these, what do you see? Especially, what do you see for “networking.service” and “NetworkManager.service”? These services need to be active for the software to function (even if configuration is correct it won’t work should the service not be told to run).
