How do I update the pinmux configuration into the module?
I am using the TX2_NX module (P3636-0010) to match the load card we designed.
I generated by pinnum form out of the three dtsi files, and successfully convert to ". CFG file ", I have update the CFG file to Linux_for_Tegra/kernel/pinmux t186ref/BCT directory below, What instructions should I use to update the.cfg file into the module?
When I use sudo./flash.sh jetson-xavier-nx-devkit-tx2-nx mmcblk0p1, the “TEGRARCM_V2 --ISAPPLET” screen appears for a long time during the burn process.
Hi Kimber,
What’t the Jetpack version in use?
Yes, you should re-flash the board to apply the modification.
Could you share the full flash log for further check?
JETSON LINUX VERSION:R37.4.2
JetPack 4.6.4
The attachment is flash.log.
flash.log (29.5 KB)
Do you mean JP4.6.4 (R32.7.4)?
Could you flash it successfully before modifying the .cfg file?
