JetsonLinuxR35.6.0 How do I update the uefi_jetson.bin file over OTA?Agx Orin
OTA to which version? R36.x?
Such replacing partial things are not going to work well. For example, we don’t support to use rel-36 UEFI to boot rel-35 rootfs.
No,I don’t change jetpack version.Only to repalce the uefi_jetson.bin files to the devices by OTA way?
You could refer the Software Packages and the Update Mechanism — NVIDIA Jetson Linux Developer Guide 1 documentation and update the bootloader only.
what’s the TARGET_BSP and BASE_BSP,I’m now using R35.6.0,don’t want to change Jetpack version,only update uefi_jetson.bin or BOOTAefi to the Agx Orin by OTA.
To update uefi_jetson.bin
, you could follow the Update and Redundancy — NVIDIA Jetson Linux Developer Guide 1 documentation
In host
cp ${YOU_CUSTOM_uefi_jetson.bin} Linux_for_Tegra/bootloader/uefi_jetson.bin
sudo ./l4t_generate_soc_bup.sh -e t23x_agx_bl_spec t23x
./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t23x/bl_only_payload -o ./TEGRA_BL.Cap t234
scp TEGRA_BL.Cap $user@${device_ip}:~/
In device
cd /sys/firmware/efi/efivars/
printf "\x07\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00" > /tmp/var_tmp.bin
sudo dd if=/tmp/var_tmp.bin of=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12;sync
sudo fwupdtool install-blob /home/${user}/TEGRA_BL.Cap ${<Device ID>}
To update BOOTAA64.efi
Your could refer to similar topic in
How to get the Device ID?
Please refer to Update and Redundancy — NVIDIA Jetson Linux Developer Guide 1 documentation
Get the Device ID of the System Firmware:
$ fwupdmgr get-devices
System Firmware ID ?not emmc?
what’s means?
Please refer to the Update and Redundancy — NVIDIA Jetson Linux Developer Guide 1 documentation section and you could know the detail of command steps .
thanks
What is your current directory?
pwd
/home/ares/jetson_orin/Linux_for_Tegra
Do you have python in your environment?
python --version
You could install python in your environment.
For example
sudo apt update
sudo apt install python
python3?
