Last week, I noticed that you released the new jetpack 5.1.5, I tried to upgrade my jetson orin nx module from 5.1.3 to 5.1.5 by online upgrade, but I found that I could only upgrade to 5.1.4, is it possible that apt has not updated 5.1.5 software? Would you please tell me how to upgrade to jetpack 5.1.5 online
I found that using SDK to write 5.1.5 can not appear super mode, do you need to manually write to achieve super, if you can upgrade online is the best
Do you follow the step from How to Install and Configure JetPack SDK — JetPack to upgrade to 5.1.5?
hi David,I followed this method to upgrade, can only upgrade to 5.1.4
I have tried, but it is not possible. I suspect that apt source has not been updated. Can you help me solve this problem
Do you do the reboot after those three commands executed?
Yes, I have restarted, but it is not working, and there is no super mode in the upper right corner
Could you execute below commands and share results with us
cat /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
OK, this is my result. At present, the upgrade to 5.1.4 will not continue to upgrade
Also help execute this command
cat /etc/nv_boot_control.conf
Some questions to confirm:
- In
, it should bet234
. Do you edit it or the default config showt194
- In
, do you use the custom carrier board or the dev kit?- You could provide the link you bought the device for us to review.
- In the/etc/apt/sources. The list. The d/nvidia - l4t - apt - source. The list that t194 is the default, I don’t have changed.
- I am not using dev kit, but the rest of the carrier board, will this affect my software upgrade
Would you please tell me how to do that
I noticed that the software above does not have 5.1.5, is this the reason why I can not upgrade to jetpack 5.1.5
Good morning David,This morning, I found that the package of jetpack 5.1.5 has been updated, and I have successfully upgraded to jetpack 5.1.5, but I still do not have super maxn mode, may I ask how to solve it?
Hi,Is there a way to upgrade to jetpack 5.1.5 super online? I need to use this version
Our official apt upgrade is for the dev kit, some package might not be compatible leading super mode not enabled.
Since you are using the custom board, we suggest you to reach out vendor to get the customized bsp.
Hi, do you mean that if I use jetson orin dev kit, can I upgrade to super version of jetpack 5.1.5 online? I also have orin dev kit, I can try it. My goal is to upgrade the image of my built environment to super version including jetpack 5.1.5, if you have a better way, please let me know, thank you
I have a jetpack 5.1.5 image that can use super mode, but it is an original image, and it is too complicated for me to rebuild the environment. I want to directly upgrade my original jetpack 5.1.3 image to jetpack 5.1.5 and start super mode normally. Is there any way to do that
Hi,I tried to upgrade to jetpack 5.1.5 online using the jetson orin dev kit and found that maxn super mode is still not available, this online upgrade method does not work. Is there any other way to achieve what I said above by upgrading the image of the existing set up environment to jetpack 5.1.5 with maxn super mode
