How do I verify if my Jetson AGX Orin Devkit was encrypted?
I have a few questions, actually. Sorry about this!
 sudo ROOTFS_ENC=1 ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh -c /tmp/os/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc_industrial_enc_rootfs_ab.xml jetson-agx-orin-devkit internal
When I flashed this right now, it seemed to not do an A/B partition on the internal. It also seemed to not encrypt my disks, but I’m not sure how can I verify that? I thought of using lsblk -o NAME,KNAME,FSTYPE,TYPE,MOUNTPOINT,SIZE to look for a type crypt but assumed Nvidia has a wrapper around crypt, so it might appear differently. I have no clue what to look for and any help is appreciated. Using R35.
# R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64, DATE: Tue Feb 20 04:46:31 UTC 2024
Solved!
The lsblk command should display your partitions with crypt or the like.
Yes, you can just run lsblk to check if there’s encrypted partition.
