hello @philipp.reist
I want to run the bolt and nut demo shown above in Isaacsim.
As a result of my search for bolts and nuts demos, I was only able to run them in the Omniverse showroom and did not have access to the stage like the author of this article.
where can i get it?
I would like to run the sample files or sources for the Physics Demo Nuts and Bolts.
Thank you for answer.
Thanks to that, I was able to run the sample.
I tried changing the collider of nut_bolt from SDF Mesh to Convex Hull to compare the difference between the sophisticated SDF Mesh and other Convex Hull and Triangle Mesh.
But I got an error message saying Can not edit attributes of instance proxy.
You can manually disable the instanceable flag on the asset, then you should be able to change to convex hull. But then it won’t be able to thread and just bump off the bolt.
