How do you enter a startup argument for Nvidia Code?
I started up Code today and it’s suddenly reading my CPU integrated graphics instead of my RTX gpu. I believe I need to enter a startup argument to disable multi-gpu, but I’m not sure how to do that. Where can I enter the following argument?
–/renderer/multiGpu/enabled=false
@stuart.taute i am just an user but i think you should be able to add/modify it in the app’s .kit file. i don’t have it in front of me, but the file should be located in and around %userprofile%\AppData\local\ov\pkg\[Code version]\ ? below is an example with the Audio2Face app:
That was the little bump I needed, thank you! Didn’t know it was called a kit file or where it was. Finding and modifying that did the trick!
the kit file is also where you can adjust some of the preferences if the setting keeps reverting back. here’s a quick write up if interested:
