Xavier+deepstream 5.0
How does deepstream app and plug-in transfer data in real time? What is the relationship between them? Different threads? Why can’t I pass data through global variables
Can you share your use case? appsrc/appsink can transfer data between application and pipeline.
I want to use the time-consuming information in the nvdsappperfstruct structure in deepstream app through \deepstream\libs\nvvisionmsgconv\nvmsgconv.cpp files are sent out.
I want to transmit the frame rate information through deepstream\gst-plugins\gst-nvmsgbroker,
Suppose you can do it as you have the source code of msgconvert and msgbroke.
Are you playing Tai Chi?
