How does orin nx8g only brush core boot QSPI?
please try the following command:
sudo ./flash.sh --no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit sda1
In case you are using a Xavier NX DevKit as the carrier board, replace jetson-orin-nano-devkit with p3509-a02+p3767-0000.
Also, just FYI, we usually use the term flash or occassionally burn, but not brush when referring to the behavior of getting the device to work with our BSP.
