Thank you for the precision !
When I use your gst-launch command I only obtain a fixed image…and this message on the terminal:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)60/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)60/1"
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)60/1"
/GstPipeline:pipeline0/GstXvImageSink:xvimagesink0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)60/1"
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)60/1"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)UYVY\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string\)progressive\,\ colorimetry\=\(string\)2:4:7:1\,\ framerate\=\(fraction\)60/1"
I don’t really get it.
Then if I use the command of the guide:
gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw, format=(string)UYVY,
width=(int)2304, height=(int)1296" ! nvvidconv ! "video/x-raw(memory:NVMM), format=(string)I420,
width=(int)1920, height=(int)1080" ! nvoverlaysink overlay-w=1920 overlay-h=1080 sync=false
I have an image that takes the whole screen and I can’t access anything, I have to “kill” the process to stop it…
