I wrote a simple code to generate an engine file from caffemodel.
def build_engine(deploy_file, model_file, outputs):
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
datatype = trt.float16
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.CaffeParser() as parser:
model_tensors = parser.parse(deploy=deploy_file, model=model_file, network=network, dtype=datatype)
# FP16
builder.fp16_mode = True
builder.strict_type_constraints = True
# output
for output in outputs:
network.mark_output(model_tensors.find(output))
builder.max_batch_size = 1
builder.max_workspace_size = 1 << 20
with trt.Builder(TRT_LOGGER) as builder:
with builder.build_cuda_engine(network) as engine:
with open('{}_{}.engine'.format(model_file, 'fp16'), 'wb') as f:
f.write(engine.serialize())
Here’s the comparison from the model in the Primary_Detector in size.
-rw-r--r-- 1 nvidia nvidia 6244865 Dec 12 08:14 resnet10.caffemodel
-rw-r--r-- 1 nvidia nvidia 8057761 Apr 9 03:01 resnet10.caffemodel_b1_fp16.engine
-rw-r--r-- 1 nvidia nvidia 8063168 Dec 12 08:14 resnet10.caffemodel_b30_fp16.engine
-rw-r--r-- 1 nvidia nvidia 6878089 Apr 10 14:08 resnet10.caffemodel_fp16.engine
is the one generated by the script above.
The one with b30 is on a TX2 box, and another with b1 is on a Nano box.
So, how, with which configurations, does the gst-nvinfer generates an engine file? I can see that output blobs names and network mode in the config file, which are covered in the script above.
Note that all the engines work fine. Not visible differences.
