How does xavier share the network with windows via usb?
Hello, how does xavier share the network with windows via usb?
We don’t enable such configuration. Maybe you can check the post over the Internet for such case.
A bit of trivia: When up and running the Xavier is able to produce a “device mode” emulation of a router. When connected to a computer’s host mode connector, it will see the virtual wired router. It is up to the host PC to use or not use the virtual wired router. The host won’t know this is a Jetson pretending to be a router, but it will choose to use or ignore the DHCP availability. If Windows uses this device and allows sharing of the internet with that router, then the Jetson gets to access the internet.
