How dose Ext::IDebugCaptureSession work?
Hallo,
How is the Argus::Ext::IDebugCaptureSession suppoesd to work?
And which information is exported via this method?
When I tried to call Argus::Ext::IDebugCaptureSession::dump(int32_t fd) I only get an empty file.
Example of my code:
bool dumpArgusDbgInfo(Argus::CaptureSession* captureSession){
    Argus::Ext::IDebugCaptureSession *iDbgCaptureSession = interface_cast<Argus::Ext::IDebugCaptureSession>(captureSession);
    if(iDbgCaptureSession) return false;
    std::stringstream ss;
    ss << "/tmp/argusDebugDump.log";
    int f = open(ss.str().c_str(), O_WRONLY | O_CREAT, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP | S_IROTH);
    if(f <= 0) return false;
    Argus::Status aStatus = iDbgCaptureSession->dump(f);
    close(f);
    if(aStatus != STATUS_OK) return false;
    return true;
I am using L4T 32.7.2
Could you check the argus_camera sample code if dump any information.
if i press the d key on the argus_camera app I also don’t get any output
Could you print some message to check if the code be called while press the “d” key.
