How i can draw track (box path) in deepstream 5.1 on osd via python api?
Hi. I find solution:!
tracks = {}
def osd_sink_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame:
try:
except StopIteration:
break
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
while l_obj:
try:
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
continue
object_id = str(obj_meta.object_id)
if obj_meta.tracker_bbox_info.org_bbox_coords.left > 0 and obj_meta.tracker_bbox_info.org_bbox_coords.top > 0:
if object_id in tracks:
tracks[object_id].append({
'x': int(obj_meta.tracker_bbox_info.org_bbox_coords.left),
'y': int(obj_meta.tracker_bbox_info.org_bbox_coords.top)})
else:
colors[object_id] = [random.uniform(0, 1) for _ in range(3)]
tracks[object_id] = collections.deque(maxlen=200)
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
for i in range(len(tracks[object_id]) - 1):
if i % 16 == 0:
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
display_meta.num_lines = 1 + (i % 16)
py_nvosd_line_params = display_meta.line_params[i % 16]
py_nvosd_line_params.line_color.set(*colors[object_id], 0.9)
py_nvosd_line_params.line_width = i // 15 + 2
py_nvosd_line_params.x1 = tracks[object_id][i]['x']
py_nvosd_line_params.x2 = tracks[object_id][i + 1]['x']
py_nvosd_line_params.y1 = tracks[object_id][i]['y']
py_nvosd_line_params.y2 = tracks[object_id][i + 1]['y']
l_user_meta = obj_meta.obj_user_meta_list
try:
l_obj = l_obj.next
break
return Gst.PadProbeReturn.OK
Glad to know issue resolved.
