• Network Type fpenet
• TLT Version 4.0
I read the latest documentation, which states that the channel parameter can be 1 and 3.
But it reports an error in actual use:
File "</usr/local/lib/python3.6/dist-packages/driveix/fpenet/scripts/train.py>", line 3, in <module>
File "<frozen driveix.fpenet.scripts.train>", line 164, in <module>
File "<frozen driveix.fpenet.scripts.train>", line 142, in main
File "<frozen driveix.fpenet.trainers.fpenet_trainer>", line 169, in build
File "<frozen driveix.fpenet.losses.fpenet_loss>", line 331, in transform_images
File "<frozen driveix.fpenet.losses.fpenet_loss>", line 382, in _apply_augmentations_to_frame
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/image_ops_impl.py", line 1875, in grayscale_to_rgb
images = _AssertGrayscaleImage(images)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/image_ops_impl.py", line 262, in _AssertGrayscaleImage
_CheckGrayscaleImage(image, require_static=False), image)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/image_ops_impl.py", line 291, in _CheckGrayscaleImage
raise ValueError('Last dimension of a grayscale image should be size 1.')
ValueError: Last dimension of a grayscale image should be size 1.
