What can I do if I got following error message on a Dell R630:
mlx5_core 0000:82:00.0: mlx5_port_module_event:1131:(pid 2265): Port module event[error]: module 0, Cable error, Power budget exceeded
The Adpater I am using: MCX556A-EDAT
The both transceivers: https://www.finisar.com/optical-transceivers/ftlc9551repm
Both transceivers are using 3.5Watt max. Only plug in one transceiver works. When inserting the second I got this message.
On a Dell R740 this message is not coming and all work as expected.
Is there any limitation due to the Dell R630. Can I change something in the BIOS ?
