• Hardware Platform (Jetson / GPU) P1000
• DeepStream Version - v6.1
• TensorRT Version :- 8.2.5-1+cuda11.4
• NVIDIA GPU Driver Version (valid for GPU only) (NVIDIA-SMI 510.85.02 Driver Version: 510.85.02 CUDA Version: 11.6)
• How to reproduce the issue? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I’m using the URIDecode bin as the source bin, implemented similarly to deep-stream-nvanalytics code (deepstream_python_apps/deepstream_nvdsanalytics.py at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub), I wanted to retrieve correct information of the timestamp from the frame, then I found the ntp_timestamp
from frame data.
After implementing it, It gives me the same time as the system time. Due to limited processing capabilities, there is a delay in the process & I’m getting the wrong ntp_timestamp
vs actual stream time
my questions are as follows,
- How I can retrieve the actual time stamp using URIDECODEBIN?
- I didn’t find any python implementation for retrieving the original time stamps using uridecodebin?
- Can you explain to us point number TWO( step-2 ) in below mentioned document with a proper python3 example ?
NTP_TIMESTAMP :- (NTP Timestamp in DeepStream — DeepStream 6.1.1 Release documentation)
