While I replaced the older OpenCV4Tegra with OpenCV3.x, using the following cli:
$ sudo apt-get purge libopencv4tegra-dev libopencv4tegra
$ sudo apt-get purge libopencv4tegra-repo
$ sudo apt-get update
outrageously, VisionWorks was found gone, OpenCV4Tegra behaving like a hoodlum.
I expect both VisionWorks and OpenCV3.x, not OpenCV4Tegra, work together. How can I do for this great?
jachen
2
Hello, viisautta:
For VisionWorks, would you please try to re-install it again and check whether it works?
For OpenCV3.x, you can make a private build directory, and with correct environment, it can work well.
Refer to https://devtalk.nvidia.com/default/topic/984327/jetson-tx1/how-to-manage-tegra4opencv-and-opencv3-1-together-on-jetson-tx1/post/5048189/#5048189, and it may help.
br
Chenjian
