Hello everyone, I got raw image data from NVBufSurface, I want to encode this raw data as JPG by NVJPEG. But there was a problem with the color format, which caused the encoded image to display incorrectly.
Through NVJPEG encoding, the output format is V4L2_PIX_FMT_YUV420M, as if the output format of NVJPEG can only be V4L2_PIX_FMT_YUV420M or V4L2_PIX_FMT_NV12.
I tried changing the color format, but it didn’t work out right.This problem has been bothering me for many days. Please help me. Thanks a lot.
My code is as follows, I modified it according to the deepstream_nvdsanalytics_meta example.
extern “C” void save_frame_with_bbox(GstBuffer *buf)
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;// Get original raw data GstMapInfo in_map_info = GST_MAP_INFO_INIT; if (!gst_buffer_map(buf, &in_map_info, GST_MAP_READ)) { g_print ("Error: Failed to map gst buffer\n"); return; } NvBufSurface *surface = (NvBufSurface *)in_map_info.data; gst_buffer_unmap (buf, &in_map_info); uint32_t frame_data_size = 0; unsigned char* src_data = NULL; std::vector<cv::Rect> objsRect; NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf); for (l_frame = batch_meta->frame_meta_list; l_frame != NULL; l_frame = l_frame->next) { NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data); guint object_num = 0, person_num = 0; for (l_obj = frame_meta->obj_meta_list; l_obj != NULL; l_obj = l_obj->next) { obj_meta = (NvDsObjectMeta *)(l_obj->data); if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) { //cv::Rect rect(obj_meta->rect_params.left, obj_meta->rect_params.top, obj_meta->rect_params.width, obj_meta->rect_params.height); objsRect.emplace_back(obj_meta->rect_params.left, obj_meta->rect_params.top, obj_meta->rect_params.width, obj_meta->rect_params.height); person_num++; object_num++; } } g_print("test: person_num=%d, object_num=%d, batchId=%d, srcId=%d\n", person_num, object_num, frame_meta->batch_id, frame_meta->source_id); if (person_num == 0) { char txt[32] = { 0 }; snprintf(txt, sizeof(txt), "%s-%d", Key_Person_Detect, frame_meta->source_id); RedisHelper::instance()->setCommand(txt, "0"); continue; } else { char txt[32] = { 0 }; snprintf(txt, sizeof(txt), "%s-%d", Key_Person_Detect, frame_meta->source_id); RedisHelper::instance()->setCommand(txt, "1"); } if (frame_data_size < surface->surfaceList[frame_meta->batch_id].dataSize) { if (src_data != NULL) { free(src_data); src_data = NULL; } src_data = (unsigned char*)malloc(surface->surfaceList[frame_meta->batch_id].dataSize); if (src_data == NULL) { g_print("Error: failed to malloc src_data \n"); return; } frame_data_size = surface->surfaceList[frame_meta->batch_id].dataSize; } else { memset(src_data, 0, frame_data_size); } cudaMemcpy((void*)src_data, (void*)surface->surfaceList[frame_meta->batch_id].dataPtr, surface->surfaceList[frame_meta->batch_id].dataSize, cudaMemcpyDeviceToHost); gint frame_width = (gint)surface->surfaceList[frame_meta->batch_id].width; gint frame_height = (gint)surface->surfaceList[frame_meta->batch_id].height; gint frame_step = surface->surfaceList[frame_meta->batch_id].pitch; gint color_format = surface->surfaceList[frame_meta->batch_id].colorFormat; JpegEncoder::instance()->encode(frame_meta->source_id, src_data, frame_data_size, frame_width, frame_height); cv::Mat frame; cv::Mat out_mat = cv::Mat(cv::Size(frame_width, frame_height), CV_8UC3); switch (color_format) { case NVBUF_COLOR_FORMAT_NV12: frame = cv::Mat(frame_height * 3 / 2, frame_width, CV_8UC1, src_data, frame_step); cv::cvtColor(frame, out_mat, CV_YUV2BGR_NV12); std::cout << "test nv12 ! \n" << std::endl; break; case NVBUF_COLOR_FORMAT_RGBA: frame = cv::Mat(frame_height, frame_width, CV_8UC4, src_data, frame_step); cv::cvtColor(frame, out_mat, CV_RGBA2BGR); break; default: break; } std::cout << "test objsRect.size = " << objsRect.size() << "\n" << std::endl; for (uint i = 0; i < objsRect.size(); ++i) { cv::rectangle(out_mat, objsRect[i], cv::Scalar(0,255,0), 1); std::cout << "test drwa rect " << i << "\n" << std::endl; } } if (src_data != NULL) { free(src_data); src_data = NULL; }
The relevant code of encode is as follows, I made the change based on the 05_jpeg_encode example in jetson_multimedia_api.
void JpegEncoder::encode(int srcId, unsigned char* src_data, uint data_len, int width, int height, int colorFmt)
width = 1920;
height = 1080;
colorFmt = V4L2_PIX_FMT_YUV420M; //V4L2_PIX_FMT_YUV420M; V4L2_PIX_FMT_NV12M
std::map<int, TContext*>::iterator iter = this->ctx_map.find(srcId);
if (iter == this->ctx_map.end())
TContext* ctx = new TContext();
ctx->set_context(srcId, width, height, colorFmt);
this->ctx_map.insert(std::make_pair(srcId, ctx));
else
iter->second->set_context(srcId, width, height, colorFmt);
}g_print("encode: srcId=%d, dataLen=%d, width=%d, height=%d\n", srcId,data_len,width,height); if (!this->jpeg_encode_proc(srcId, src_data, data_len)) { g_print("jpeg_encode_proc run failed\n"); } return;
int JpegEncoder::jpeg_encode_proc(int srcId, unsigned char* src_yuv_data, uint src_yuv_len)
int ret = 0;
int error = 0;TContext *ctx = this->get_context(srcId); if (!ctx){ return -1; } ctx->of_stream = new std::ofstream(ctx->outfile_path()); TEST_ERROR(!ctx->of_stream->is_open(), "Could not open output file", cleanup); ctx->jpegenc = NvJPEGEncoder::createJPEGEncoder("jpenenc"); TEST_ERROR(!ctx->jpegenc, "Could not create Jpeg Encoder", cleanup); /** * Case 2: * Read YUV420 image from file system to CPU buffer, convert to hardware * buffer memory (DMA buffer fd), encode by encodeFromFd() then write to * file system. * Note: * While converting to hardware buffer, NvVideoConverter may convert * YUV420 to NV12 depends on ctx.in_pixfmt. */ ctx->convert = NvVideoConverter::createVideoConverter("conv"); TEST_ERROR(!ctx->convert, "Could not create Video Converter", cleanup); /* Set conv output plane format */ // V4L2_PIX_FMT_YUV420M ret = ctx->convert->setOutputPlaneFormat(V4L2_PIX_FMT_YUV420M, ctx->in_width, ctx->in_height, V4L2_NV_BUFFER_LAYOUT_PITCH); TEST_ERROR(ret < 0, "Could not set output plane format for conv", cleanup); /* Set conv capture plane format, YUV420 or NV12 */ ret = ctx->convert->setCapturePlaneFormat(ctx->in_pixfmt, ctx->in_width, ctx->in_height, V4L2_NV_BUFFER_LAYOUT_BLOCKLINEAR); TEST_ERROR(ret < 0, "Could not set capture plane format for conv", cleanup); /* REQBUF, EXPORT and MAP conv output plane buffers */ ret = ctx->convert->output_plane.setupPlane(V4L2_MEMORY_MMAP, 1, true, false); TEST_ERROR(ret < 0, "Error while setting up output plane for conv", cleanup); /* REQBUF and EXPORT conv capture plane buffers * No need to MAP since buffer will be shared to next component and not read in application */ ret = ctx->convert->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 1, !ctx->use_fd, false); TEST_ERROR(ret < 0, "Error while setting up capture plane for conv", cleanup); /* conv output plane STREAMON */ ret = ctx->convert->output_plane.setStreamStatus(true); TEST_ERROR(ret < 0, "Error in output plane streamon for conv", cleanup); /* conv capture plane STREAMON */ ret = ctx->convert->capture_plane.setStreamStatus(true); TEST_ERROR(ret < 0, "Error in capture plane streamon for conv", cleanup); /* Register callback for dequeue thread on conv capture plane, this callback * will encode YUV420 or NV12 image to JPEG and write to file system. */ ctx->convert->capture_plane.setDQThreadCallback(conv_capture_dqbuf_thread_callback); // Start threads to dequeue buffers on conv capture plane ctx->convert->capture_plane.startDQThread(ctx); /* Enqueue all empty conv capture plane buffers, actually in this case, 1 buffer will be enqueued. */ for (uint32_t i = 0; i < ctx->convert->capture_plane.getNumBuffers(); i++) // getNumBuffers() = 1 { struct v4l2_buffer v4l2_buf; struct v4l2_plane planes[MAX_PLANES]; memset(&v4l2_buf, 0, sizeof(v4l2_buf)); memset(planes, 0, MAX_PLANES * sizeof(struct v4l2_plane)); v4l2_buf.index = i; v4l2_buf.m.planes = planes; ret = ctx->convert->capture_plane.qBuffer(v4l2_buf, NULL); if (ret < 0) { std::cerr << "Error while queueing buffer at conv capture plane" << std::endl; abort(ctx); goto cleanup; } } /* Read YUV420 image to conv output plane buffer and enqueue so conv can start processing. */ { struct v4l2_buffer v4l2_buf; struct v4l2_plane planes[MAX_PLANES]; NvBuffer *buffer = ctx->convert->output_plane.getNthBuffer(0); memset(&v4l2_buf, 0, sizeof(v4l2_buf)); memset(planes, 0, MAX_PLANES * sizeof(struct v4l2_plane)); v4l2_buf.index = 0; v4l2_buf.m.planes = planes; for (uint32_t i = 0; i < buffer->n_planes; i++) { NvBuffer::NvBufferPlane &plane = buffer->planes[i]; plane.bytesused = 0; uint32_t bytes_writed = plane.fmt.bytesperpixel * plane.fmt.width; unsigned char* dstdata = plane.data; unsigned char* srcdata = src_yuv_data; for (uint32_t j = 0; j < plane.fmt.height; j++) { memcpy(dstdata, srcdata, bytes_writed); // ??? srcdata += bytes_writed; // ??? dstdata += plane.fmt.stride; } plane.bytesused = plane.fmt.stride * plane.fmt.height; } ret = ctx->convert->output_plane.qBuffer(v4l2_buf, NULL); if (ret < 0) { std::cerr << "Error while queueing buffer at conv output plane" << std::endl; abort(ctx); goto cleanup; } } /* Wait till all capture plane buffers on conv are dequeued */ ctx->convert->capture_plane.waitForDQThread(2000);
cleanup:
if (ctx->convert && ctx->convert->isInError())
std::cerr << “VideoConverter is in error” << std::endl;
error = 1;
if (ctx->got_error) {
error = 1;
// delete ctx.in_file;
if (ctx->of_stream){
delete ctx->of_stream;
/* Destructors do all the cleanup, unmapping and deallocating buffers and calling v4l2_close on fd */
if (ctx->convert){
delete ctx->convert;
if (ctx->jpegenc){
delete ctx->jpegenc;
}return -error;
static bool conv_capture_dqbuf_thread_callback(struct v4l2_buffer *v4l2_buf, NvBuffer * buffer, NvBuffer * shared_buffer, void * arg)
TContext *ctx = (TContext *) arg;
unsigned long out_buf_size = ctx->in_width * ctx->in_height * 3 / 2;
unsigned char *out_buf = new unsigned char[out_buf_size];
int iterator_num = ctx->perf ? PERF_LOOP : 1;
int ret;if (!v4l2_buf) { std::cerr << "Failed to dequeue buffer from conv capture plane" << std::endl; abort(ctx); delete[] out_buf; return false; } if (v4l2_buf->m.planes[0].bytesused > 0) { for (int i = 0; i < iterator_num; ++i) { ret = ctx->jpegenc->encodeFromFd(buffer->planes[0].fd, JCS_YCbCr, &out_buf, out_buf_size, ctx->quality); if (ret < 0) { std::cerr << "Error while encoding from fd" << std::endl; ctx->got_error = true; break; } else{ std::cout << "encodeFromFd success!" << std::endl; } } if (ret >= 0) { ctx->net_send = false; if (ctx->net_send) { // send to network } else { if (ctx->of_stream) { ctx->of_stream->write((char*)out_buf, out_buf_size); } } } } delete[] out_buf; return false;
• Hardware Platform (Jetson NX)
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.4.1
