I’m aware that it’s technically possible to connect a large number of GPUs to a PC for mining purposes Asus has a motherboard that supports up to 19 GPUs | PC Gamer, but how many of these can actually be used simultaneously for graphics output?
For example, if I wanted to use these all independently for a CAVE Cave automatic virtual environment - Wikipedia like system, where each GPU will render its own independent view to its own monitor. There should be very little interaction between GPUs. Is there some limitation of the OS, or graphics driver that would prevent me from doing this with more than something like four cards?
To be clear, I’m not interested in anything like SLI here, just using each GPU independently from a single application (think split screen rendering, but each player having their own monitor). I’m currently experimenting with this from Vulkan with two GPUs, but the graphics API isn’t important to me if that puts some limit on this. I’m just curious what the upper limit is for this kind of setup.
Here’s an older example of the kind of system I have in mind: OCTAVIS: Optimization Techniques for Multi-GPU Multi-View Rendering — JVRB - Journal of Virtual Reality and Broadcasting
