I’m a noob at developing system with tx1 and I have one question
I really hope you guys will answer to my question soon ( sorry for my poor English ^^;; English is not my mother language )
I’ve tried to design a machine vision system with three Basler Cameras ( USB 3.0 , 1920 x 1200 , 40fps ) and only one Jetson TX1 Board
But I doubt whether TX1 could handle three USB 3.0 Cameras
*Important point
I want that 3 Basler Cameras can capture Images simultaneously in my TX1 machine vision system
Anyway how many USB 3.0 Cameras have you tried with TX1 ? did it work fine?
The theoretical USB3.0 speed is 5Gbps(625MB), if there is no other type USB device(Bulk, interrupt) to share bandwidth, USB host can allocate 5Gbps * 90% = 562.5MB for iso transfer.
In your case, 3 Basler Cameras can capture Images simultaneously - that will require ~ 474MB (3x 1920x1080 x 40fps x 2 B/pixel).
Thus, the bandwidth requirement is still under the limitation, 474MB < 562.5MB, there should be no problem to support your use case on TX1, however we did not test with 3 USB 3.0 cameras yet.
