How modify I clk_source of aon_cpu_nic?
I found the aon_cpu_nic’s clk rate is 38.4mhz, but the clock rate of spe is 200Mhz maxinum. So I want to change parent of aon_cpu_nic to pll_aon.
What method should I use?
1.Should I modify the kernel dts?
2. Should I modify the clock directly in spe?
No, that’s not supported yet.
br
ChenJian
