Hey all, so I have Qwen 3.5 122B Flash running on a single spark. I have been fairly happy with it, but it does loop occasionally. The code also isn’t always perfect. For 3k investment, I am satisfied.
However, I have been told that DS4F on 2x Sparks is essentially “in another world” quality wise. How true is this, in your experience? Investing 4k more into this platform is a difficult pill to swallow (well and $180 for the cable to connect the two).
Thanks. I am using it to code some projects for myself, and will in the future be using it for financial document ingestion. At the moment it’s just handling ingestion and large-token categorization duties.
Does it also support image recognition and anything that 122B would do, but simply better? Are there some examples of what you would try to do with 122B where it would completely fail, but DS4F would handle it flawlessly? I’m just trying to get a feel for the quality difference.
It’s not multimodal, text only. Advantages over 122b: wide knowledge, deep reasoning, good orchestration ability, nerdy (developed for quants by quants - deepseek roots is a quant tranding firm), good tool calling, 1M context.
Advantages of 122b: even better tools calling, multimodal (if your quant supports it), faster. On a single spark you only can run deepseek in q2xxs format with short context using DwarfStar, so 1M context is not practical due to RAM limitation and speed limitation.
On two sparks - DS4F works fully (but stil developing story - but many folks me included use it for production for over a month now), 2M+ context cache, 1M per session - completely real, usable speed even at 500k+.
PS I would suggest try to use DwarfStar version for real workflow, just clench your teeth with slower speed. In general abilities and strengths will be same as for 2-spark DS4F. Just better quality due to being FP4-FP8 versus iq2, much better speed and full context.
Yes, I have seen that q2xxs quant mentioned here and there, but many have said that it loses too much going down to that size. I assume that even if I were to try it, I wouldn’t really get a good approximation for how well DS4F runs, right?
I did reserve one more Asus Ascent (and the cable) from Microcenter, so I am just on the fence about whether I want to try it or not. Maybe there isn’t really any harm in just experiencing it and then returning the product if I don’t like it enough.
122B Autoround with flash inference, my main issue is that it starts looping (during reasoning, sometimes during output) too regularly for my taste. I would be curious if DS4F loops much less. I have to be very careful with my prompts.
Anyway thanks for giving me a breakdown. I’ll leave the topic open a bit longer in case anyone has any additional opinions on this.
Well I initially tested while ago and was also skeptical, mainly because of low speed and context. But to try and get a feel of it before committing - good idea. Now I set it up as a backup/travel inference on my macbook and tested it profusely - it does surprisingly well, antirez magic is unbelievable. The guy who created it is the same guy to shook dev community with Redis/Redis cluster, half internet relies on it for caching (my projects too). Now this guy is doing magic for local inference for both macs and sparks.
PS for looping avoidance change the kwargs it chat template - either in your harness settings or defaults on launch - set temperature not too low - 0.5-0.6 is a good balance to introduce a little randomness and give generation a slack to break a cycle, also add penalties for looping like repetition penalty 1.05-1.1 and presence penalty 1.05
How much context does the DGX Spark get from that DS4 from antirez? I don’t really see any specific number being mentioned, scanning through the readme.
With regards to 122B:
I am using 0.6 for all of my tasks, including categorization at the moment. I think I tried repetition and presence penalties, but in some cases it didn’t help. For instance, there is this one piece of Japanese which I had it translate to English, and there was a lot of buildup before an emphatic exclamation and incredulous by the protagonist. Well a little too incredulous it turns out, as it would start looping the “Y” on the end of “WHY” endlessly, even in its reasoning phase. I wonder now if that might have also been a product of prompt caching causing it to always have that return state even if I tried it multiple times.
I would be curious to see how DS4 could translate it, but obviously all it took to get around that was a little modification to the text (removing a few exclamation points on the piece of text being translated), and that’s hardly a reason to throw down 4k more on a better solution.
Overall, kind of on the fence. I appreciate you giving me some perspective. It probably won’t end up being worth it, if I’m mostly just learning about AI and using it in the hobbyist/personal space. Maybe the 122B model is plenty for that, despite its faults. But I also wouldn’t mind trying it just to see. First I guess I will try the Antirez single spark version.
You could have been up and running dwarfstar during this time you are asking questions. It’s the easiest and fastest engine to build and run. It boots in 15 seconds, as opposed to 3-15 minutes to VLLM configs, and its pure C - build is fast, efficiency is top. Play with it.
