How much power can be pulled through the M.2 M Dev kit connector
How much current can be pulled through each 3.3V pin on the M.2-M connector.
It is up to ~2.1A.
Is that the total that can be pulled from the 3V3 supply or can a total of 10A be pulled through the 9 3V3 pins on the M.2 connector on the Orin Dev Kit?
Is a datasheet available for the M.2 connector, since the one referenced in the datasheet is not available online?
Please ignore the ~10A and refer to below spec in Jetson Orin Nano Developer Kit Carrier Board Specification
